Dyno and Tire Size
Old Oct 9, 2009 | 09:11 AM
Hvymtlc5's Avatar
Hvymtlc5
Default Dyno and Tire Size
Does tires size affect a dyno reading or is that compensated for by the operator?
I normally run stock tires (285/40/18) but am running some 305/45/18 now which are a lot taller than stock - changing my 3.41 gear ratio to something less.
Old Oct 9, 2009 | 09:42 AM
David426's Avatar
David426
Stock tires are 275/40/18 and your gearing should be 3.42,3,15 or 2.73 never heard of a 3.41. At any rate it does not really make a difference because the dyno measures horsepower at the rear wheels regardless of tire size,wheel size or gear ratio. Your gear ratio, however is changed with a taller or shorter tire than what was on there stock.. Taller tire equates to a taller gear ratio(not good for drag racing) A shorter tire will give you a shorter ratio.. The difference is very minimal, unless you decide to do the ethnic thing and put 22 or 24 inch rims on your car, these guys are bringing 3.08:1 ratio down to a 2.56:1 with these giant wheels
Old Oct 9, 2009 | 10:34 AM
Hvymtlc5's Avatar
Hvymtlc5
Didn't know if the car would pull hard enough with the gearing change...but as you said...its; not a factor so I'll save myself the trouble of switching them out.
Old Oct 10, 2009 | 01:38 PM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
Smaller tires would get you into the powerband faster therefore your best numbers would be a little lower in the rpm range.
To Dyno and Tire Size
