Cold Air Intake
Old Oct 10, 2009 | 08:02 AM
AU N EGL's Avatar
AU N EGL
Originally Posted by karateboi87
Hm.. vortex does bring air from where radiator gets air.. just like Honker.
Additionally, the honker comes with the pre-cut shroud but that's because it's $500.. you can just buy another shroud.
When you have a system like honker/vortex, you can open up fog light area and let air cool engine down.
and or you can put duct tape of the screens for better aerodynamics or just to keep dirt out of the engine bay
Old Oct 10, 2009 | 10:39 AM
DARRYLZO6's Avatar
DARRYLZO6
I love a good healthy debate. I only bring up the DIY shroud modification because A- who wants to spend money when they dont have to B- usually to get a system with the shroud pre-cut is usually at least $400-$500 brand new and C- the radiator scoop will usually work well with just about any type aftermarket intake.
Old Oct 10, 2009 | 11:07 AM
dndrsn's Avatar
dndrsn
I am not aware that Callaway sells a pre-cut shroud for the Honker. Usually buying one pre-owned will get you a shroud that is cut.
If you don't mind modifying your radiator shroud, then do "this" and save yourself hundreds of dollars.
Old Oct 10, 2009 | 07:23 PM
DARRYLZO6's Avatar
DARRYLZO6
Thats a great mod if you are gonna keep the stock intake. And the only expense is another panel filter. Instead of a K&N I would probably go with a Blackwing panel filter.
Old Oct 11, 2009 | 10:38 PM
waddisme's Avatar
waddisme
I have this Honker knockoff I bought for my car but will not fit due to oil cooler. It is a true cold air intake, with new filter and a power duct and couplings. You can save your stock shroud and reinstall and sell this when you get rid of your car. Asking $250 shipped. Let me know if interested.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Oct 11, 2009 | 10:51 PM
pewter-FRC's Avatar
pewter-FRC
i just bought a dual cone off ebay, $24.95 for the kit. took 15 minutes to install and works and looks great
Old Oct 11, 2009 | 11:05 PM
frc99c5's Avatar
frc99c5
Hey pewter.. I bought the exact same one about an hour ago.. aluminum with dual cone filters.. can you post pics?! $50 bucks seems almost too cheap
Old Oct 12, 2009 | 11:33 AM
DARRYLZO6's Avatar
DARRYLZO6
Waddisme.... If my memory serves, that looks like the MTI True Ram Air System. I bought one a few years ago and currently Im using the modifies scoop part for my updated system. Its a pretty good system as is.
Old Oct 12, 2009 | 12:25 PM
waddisme's Avatar
waddisme
Actually, that is what it is. I used the scoop without the shroud for the 800 mi breakin period for my motor. I wish it would have fit, but I needed an oil cooler for road racing. It is a good deal for someone.
Old Oct 12, 2009 | 01:18 PM
DARRYLZO6's Avatar
DARRYLZO6
I dont know if MTI stiil sells that pert or if they are still in business but it is a good system especially with a Blackwing panel filter. And at that price is a baigain compared to other intakes. And its rare. I havent seen any other system like that up so far. But I can say from first hand experience its a very good system.
Old Oct 12, 2009 | 02:28 PM
chaase's Avatar
chaase
St. Jude Donor '12
I use a Halltech Stinger and opened up the fog light surrounds.
Old Oct 12, 2009 | 02:33 PM
Corvettes of Dallas - Parts's Avatar
0Corvettes of Dallas - Parts
Former Vendor
PM Sent
Old Oct 12, 2009 | 02:40 PM
  #33
dangerz's Avatar
dangerz
St. Jude Donor '09-'10
Is there a difference between the Honker and using a Blackwing with the license plate front opened up?
Old Oct 12, 2009 | 03:37 PM
  #34
DARRYLZO6's Avatar
DARRYLZO6
I would think that the license plate mod would be more effective ...front end feeder as opposed to bottom feeder, especially if you have some sort of sealed setup and definetly better than no ram air setup.
Old Oct 12, 2009 | 03:53 PM
  #35
jrprich's Avatar
jrprich
Don't forget the vortex rammer...
It draws air from under the car.. the same way Honker does it. I'm satisified with it
Mine works well
Old Oct 12, 2009 | 03:56 PM
  #36
jrprich's Avatar
jrprich
Originally Posted by Indy
If you're going with the twin cone intake, I suggest you also think about cold intake fog light screens (older C5s had a closed housing). The openings on each side will channel air directly to the cone filters. That'll make it more of a cold air intake.
http://www.ecklers.com/product.asp?p...6&dept_id=1353
Just remember when you open up these intakes all the dirt and crud will flow into your engine bay.........just sayin
And the price over $70 !! You can just cut out the back of your existing shrouds with a dremel, saber saw, etc.
Old Oct 12, 2009 | 04:25 PM
  #37
DARRYLZO6's Avatar
DARRYLZO6
Thats true. But if you have a sealed system you keep the dirt to a minimum. Its a trade-off. Occasionally engine bays get dirty/dusty and sometime you have to tidyem up a bit. On the other hand, I love the intake noise, added horsies, and a cooler engine bay!!
To Cold Air Intake
Old Oct 12, 2009 | 04:42 PM
  #38
C5XTASY's Avatar
C5XTASY
If you need to cut the shroud on the Honker and Vortex, the air that feeds them must flow right next to the radiator. How is that air as cool as what feeds the Vararam, especially at idle when intake air is moving slowly? I have neither, I run a Blackwing with cutouts in the foglight shrouds. Just wondering if I'm missing something here. Can anyone explain?
Ed
Old Oct 12, 2009 | 05:33 PM
  #39
DARRYLZO6's Avatar
DARRYLZO6
I dont know how everyone elses Vette runs but I have a Blackwing intake, Vararam power duct with a scooped radiator shroud and a 160 thermostat and even at idle i never run over 190 degrees. So I have no complaints. I know that depending on the modifications on each car, the temps can vary. For instance, if youre running a hotter cam , aftermarket intake manifold, headers, cats, (or no cats) and the stock cooling system , I know guys with similar setups that are running at least 235degrees and up. I also removed a few inches of the hood seal at the bottom drivers side below the windsheild to help vent the warm engine air. So far everything seems to be ok.
Old Oct 12, 2009 | 06:06 PM
  #40
pewter-FRC's Avatar
pewter-FRC
