Battery goes dead
Old Oct 9, 2009 | 07:06 PM
omegac1's Avatar
omegac1
Default Battery goes dead
I have a new to me 2003 and just put a new optima battery in it so I know that the batt is good. I noticed that after sitting for a couple of weeks the battery goes dead. I used a current meter and there is about 160 ma being drawn from the battery with the car just sitting and "nothing" turned on. That sounds high to me. Can someone measure their car and tell what it should be?
Old Oct 9, 2009 | 07:15 PM
byronhunter's Avatar
byronhunter
Should be <20 MA after 15 minutes or so, when all computers go to sleep.
Old Dec 23, 2009 | 08:28 AM
woodvette03's Avatar
woodvette03
i am having a similar prob with my 2003. mine will go dead within hours though. did you figure out anything?
Old Dec 23, 2009 | 09:52 AM
rebelheart's Avatar
rebelheart
Sounds like it is time for a battery to me.Those optimas dont seem to hold up very well unless kept on a battery tender.
Old Dec 23, 2009 | 01:44 PM
EHGVETTE's Avatar
EHGVETTE
Default oPTIMA BATTERY
I just got an education on Optima batteris. When brand new check the voltage.It should be 12.8 volts. If they drop below 10.5volts you have to hook the battery to another fully charged battery ,then put on charger.
A c-tek maintainer is a must if you don't drive the car often.
Odssey batteries are better,but more $$$$$$$$$$$.
Hope this helps.
Old Dec 23, 2009 | 02:25 PM
lwise4's Avatar
lwise4
Default Optima
I put an Optima in mine 3 years ago and it works fine. With your ampmeter in place, star pulling main fuses to see which circuit is causing the drain then check out everyihing in that circuit. The shop manual is a must have for these problems.
Years ago I got a Fiat X19 very cheap because of a battery drain problem. I found about 4 shorts in the wiring. The cigar lighter wires were melted and the wiring bundle inside the steering column were fused togeather. The car ran but the battery would go dead overnight.
Old Dec 23, 2009 | 02:28 PM
lucky131969's Avatar
lucky131969
Very important, and seemingly overlooked based on the responses.
Old Dec 23, 2009 | 02:29 PM
curtbriggs's Avatar
curtbriggs
Check that the instrument panel light switch on the far left is off. Happened to me, easy to miss during the day. If it's in the click (full on) detent, some of the interior lights are on all the time. My car is a 99.
I keep a Battery Tender on my Yellow Top Optima. I may not drive it for a month or longer.
Old Dec 23, 2009 | 03:10 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
My OPTIMA is 6 years old and it can sit idle for 35 days and STILL crank the engine. If you have to keep a battery tender on the battery to have the car to start, you have excessive current drain issues.
Fully charge the battery and go have it tested. They should fully load it with a tester and see what the load voltage is and if it recovers.
I have a detailed list of things to check to see if they turn OFF when there suppose to at home. I will post the link to the post when I get home.
Be careful about pulling fuses. You can disturb the BCM and some fuse pulls will wake up the BCM and give you a false reading
The most common current grabbers are Installed ACCESSORIES
Drivers seat multi switch and or lumbar switch
Memory driving the drivers seat continuously
Bose amp relay stuck on.
Interior light/s hood lights remaining on
Dash lights never turning OFF
HVAC Fan turning on by is self (bad controller)
Head light control module malfunction. Feel it. If its WARM or HOT it having a bad day.
Un-plug big stuff and see what happens. 20ma is the goal.
BC
Old Dec 25, 2009 | 05:02 AM
egrand333's Avatar
egrand333
Had an Optima Redtop in my 97 when I purchased the car a few months ago. Battery was about 2 years old but went dead after 2-5 days. Replaced it with a new Delco. After sitting for 3 weeks the car started right up.
Old Dec 25, 2009 | 11:43 AM
curtbriggs's Avatar
curtbriggs
Don't forget that the reason for using a gel cell type battery like the Optima is that the battery sits over the computer. A defective standard type battery that develops a leak in the case can ruin the computer.
Old Dec 25, 2009 | 11:55 AM
SNOTRKT's Avatar
SNOTRKT
My battery went dead as well, I installed a yellow top Optimax and noticed the draw again. Turns out the aftermarket stereo draws enough power that the battery will go dead within a month, also the original battery must have had a weak cell cause it would die in a week. I unplugged the stereo and things got alot better, that was the problem I had. Now i run a battery tender and things are fine.
Old Dec 25, 2009 | 12:32 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If im not mistaken, OPTIMA Batteries are NOT gel cell bateries. There a SPIRAL wound wet cell sealed battery.
BC
Old Dec 29, 2011 | 04:20 PM
#1Bamafan's Avatar
#1Bamafan
2nd Gear
Unplug the vanity lights in your sunvisors. The spring in the cover gets weak over time and isn't able to fully open the switch to cut off the light.
Old Dec 29, 2011 | 04:52 PM
TheoZ's Avatar
TheoZ
If you Google "Paul Koerner Seminar on C5 Column Lock Issues" you will find some very interesting videos with detailed information on batteries for C5 Corvettes and the special needs our cars seem to have in regard to battery voltage and reserves.
Old Dec 29, 2011 | 05:25 PM
had2have-it's Avatar
had2have-it
I had an Optima battery in my '99, if I went any longer than 2 days without connecting a battery tender there would be a substantial voltage drop. If it's an Optima, you must use a battery tender, and when they experience a significant discharge they may never come back. I now have a 6yr AC Delco and no issues.
Old Dec 29, 2011 | 09:35 PM
Rebel 1's Avatar
Rebel 1
Our '02 and '09 pull 17-20 MA each.
To Battery goes dead
