brake system flush
Old Oct 10, 2009 | 12:34 AM
oh6driver's Avatar
oh6driver
Default brake system flush
can anyone tell me if you have to use a pump the flush your brake system on a 99 coupe or can you simply just drain and refill and bleed the system. thanks scott
Old Oct 10, 2009 | 05:20 AM
c3andc5's Avatar
c3andc5
Get the speed bleeders. It makes bleeding a one-man job and so easy.
Old Oct 10, 2009 | 09:02 AM
rws.1's Avatar
rws.1
another speed bleeder fan
Old Oct 10, 2009 | 09:12 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
You do not have to purchase anything other than brake fluid. The braking system on these cars can ble flushed and bled like any other. Follow the recommended sequence for bleeding in the service manual, there are some differences in the lay-out of the hydraulic lines between the different model years.
You could probably drain it and re-fill it, but it is much faster to use the pedal to remove the old fluid.
To brake system flush
