Yella Terra Rockers
Old Oct 10, 2009 | 01:41 PM
donkelso's Avatar
donkelso
Default Yella Terra Rockers
I am considering upgrading to yella terra rockers. I have a mild cam installed (Crane 220/224/114 .551/.551) and need some advice on whether to go with the 1.7 or 1.8 ratio. I would like to get a little more power from my setup, but don't want to compromise reliability or driveability. I have Patriot dual springs. Thanks for advice.
Old Oct 10, 2009 | 11:12 PM
Mike94ZLT1's Avatar
Mike94ZLT1
I've got them, and I love them! They quieted my valvetrain immensely. I'd stick with the 1.7's, if you go to a larger cam in the future you might have clearance issues with the 1.8s.
Old Oct 11, 2009 | 01:51 AM
Last C5's Avatar
Last C5
The 1.8s will take you to a .583 lift which should be OK with your Patriots. This will net you a bit more power, but if you change cams later the 1.8's will probably have to be replaced.
Old Oct 12, 2009 | 10:39 AM
2079's Avatar
2079
What's the formula to calculate this please. Thanks
Old Oct 12, 2009 | 11:04 AM
SDPC's Avatar
0SDPC
Former Vendor
Take your lift and divide by 1.7, then multiply the result by 1.8
You should be fine with the 1.8s as long as you know you won't be going with a larger cam later on.
To Yella Terra Rockers
