Clutch recommendations?
CNC LS3 heads, 11:1 compression, ported intake, headers, exhaust, 4.10 gears, etc.
I was going to reinstall my 3k mile LS7 clutch, but bent a pressure plate finger when I yanked the motor out. It seems that the LS7 clutch is on indefinite backorder... any other clutches that would be good enough for my application that are reasonably priced and obtainable?
thanks!
Are you going with the L76 intake with the L92s you're using?(or the new F.A.S.T.) I like Spec clutches. I use a Spec 3+ for my 427(w/L92 heads & L76 intake, ported, of course)
