I did my front hubs this weekend and found that sometime after I put the wheels on, something caused the wheel to hit the caliper and rub . This was not noticeable when the wheels were installed (I did it myself and checked for clearance).
At any rate, check this out (from the rear of the wheel):
A close up of one "spoke":
here's the side edge of a spoke:
So I clearanced the caliper from with a die grinder and repainted:
Now there is plenty of room
The gouge you can see in the pictures is just under 0.100" deep. Do you think I need to replace the wheel?
The gouge you can see in the pictures is just under 0.100" deep. Do you think I need to replace the wheel?[/QUOTE]
i dont think you would need to replace it, but i would definitely smooth out the area. a gouge like that will cause a stress concentration. smooth it out so you cant see the gouge anymore with a grinder, and i think you should be ok.
