Grinding noise in window?
Old Oct 12, 2009 | 02:43 PM
Casselvette's Avatar
Casselvette
Default Grinding noise in window?
I did a search on this but did not see anything specific to my issue.
The driver side window on my C5 just recently started making a grinding or scraping noise at the "top end" of the window movement. As the window starts down it makes this noise and when it's almost to the top position (as it is going up) it makes the noise.
Any thoughts would be greatly appreciated.
Thanks,
Casselvette
Old Oct 12, 2009 | 07:21 PM
TEXHAWK0's Avatar
TEXHAWK0
Good chance it is the drive cable, but the only way to know for sure is to remove the door panel and look to see if there is anything rubbing as the glass nears the top.
You might be able to remove the rubber plugs in the bottom of the door and see what is going on, but if the problem is at the top of the door, it will be difficult to see from the bottom.
I had one window that made a gravel noise and I never did find anything that was rubbing. I replaced the window regulator assembly and the noise went away.
Does the noise change depending on whether the door is open or closed?
Old Oct 12, 2009 | 10:01 PM
2EZ 2SPD's Avatar
2EZ 2SPD
my drivers door did the same thing and it was the cable
Old Oct 13, 2009 | 04:55 AM
'02magredZ51's Avatar
'02magredZ51
Vote number three for the drive cable. Mine had almost completely separated. I found it hanging on by one strand.
Old Oct 13, 2009 | 11:37 AM
cvalvarez77's Avatar
cvalvarez77
Make me number 4... Changing mine out on friday!
Old Oct 13, 2009 | 12:41 PM
Casselvette
Thanks everyone for the information. I will remove the panel and take a look. I already have the passenger side window relay to replace so I might as well remove the driver's side panel as well. It's the pits when you have issues with both windows.
Where's the best place to purcahse the cable?.
Thanks again,
Casselvette
Old Oct 13, 2009 | 07:50 PM
2EZ 2SPD's Avatar
2EZ 2SPD
I replaced my window motor and regulator. I got mine here local but there are forum vendors that are cheaper than the dealer. Good luck
Old Oct 13, 2009 | 09:30 PM
thetaxman's Avatar
thetaxman
Thanks again,
Casselvette
I used the ebay 150 , free shipping
Old Oct 14, 2009 | 03:21 AM
'02magredZ51
I used gmpartsdirect. They were even able to send it to my APO.
Old Oct 14, 2009 | 12:07 PM
Casselvette
Great information guys. Thanks again for all your help.
Casselvette
Old Oct 14, 2009 | 08:17 PM
Bop Bop's Avatar
Bop Bop
In my experience with electric windows it's not long after the grinding noise starts the cable brakes. After changing 4 in my Chevy truck the past few years I can do it in 45 minutes.
It also pays to by quality replacement regulators (cheap replacements is why I've changed 4) and if you are good you can use the same motor.
To Grinding noise in window?
