Heater / control ?? problems
Old Oct 14, 2009 | 12:43 PM
Masummerrain's Avatar
Masummerrain
Default Heater / control ?? problems
I had my HAVC controls re-solded back in the spring (by a prof.) a/c worked fine / everything I thought was fine // last week went for a ride and needed heater and had only hot / warm air pass. side // the auto control would not let me set my controls to recirculate air // only fresh air settting // driver side was getting only outside air and was not warm / while pass. side worked OK // called the PROF. and he going to get back to me BUT in the mean time does anyone have ideas.... much thanks.
Old Oct 14, 2009 | 03:32 PM
andrewdonald1's Avatar
andrewdonald1
did you check the DIC for HVAC codes?
Old Oct 15, 2009 | 11:24 AM
Masummerrain
NO ''' /// thanks NO codes found /// could it still be the HVAC controls /// there are five actuators // 1 - air inlet (don't think it this one = outside air comes in // 2 - MODE actuator // 3 - defroster actuator (again don't think it this one) 4 - (LH) Temperature actuator -this is a electric actuator (maybe??? just because its the LH (left half ?) // 5 - (RH) Temperature actuator (electric) these are not easy jobs but can be done just need idea which ONE or ones THANKS
To Heater / control ?? problems
