HUD Install Help
Old Oct 15, 2009 | 08:14 PM
Dale M's Avatar
Dale M
Default HUD Install Help
Hi guys,
Got my heads up display today, the projector, the switch, the twelve pin connector. I have everything except the bezel.
Is it possible to install all of this in my 2001 z06 and install the bezel later without taking everything apart again?
The reason I'm asking is that it's going to be a warm weekend, and a good time to install it. I ordered the bezel, but it's three weeks away. Does the bezel go on top of the dash pad, and can I stick it on later? With 2 sided tape or something?
Thanks guys!
Dale M
Old Oct 16, 2009 | 12:00 AM
rbrtclk's Avatar
rbrtclk
When I installed my HUD, I used the bezel as a template to mark my dash for cutout and fitment. I would imagine you could do it your way, and install it later. If you use double stick tape, be sure to clean your dash area well with alcohol. Good luck.
