awesome... Check Engine Light
Old Oct 15, 2009 | 09:22 PM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
Default awesome... Check Engine Light
So I got into my 2000 coupe for the first time in 2 weeks and I got a check engine light.
The battery was almost dead a few days ago, and I had it on a trickle charger, so when I ran codes, I know there are a few that are due to that. I've never had the Check Engine light though... can a low voltage cause it?
Here are the codes, BTW:
PCM
1518
TCS
1225
1236
1243
BCM
0432
0503
0508
2592
L/R door had the same codes
2282
2284/85
1064
SCM
0851
I looked here
http://www.stengel.net/diccodes.htm
but didn't find anything outstanding.
Old Oct 15, 2009 | 09:35 PM
BlueDragon's Avatar
BlueDragon
Prolly was low bolts! Could be bad or loose grounds. (doubtful if you have not had problems in the past.)
You got too many at one time. Reset them and watch to see how they come back if they ever due!
I usually dump mine every so often to see what is happening. But then again I am one of those guys that use an HP tuner.
Rots a Ruck.
Old Oct 15, 2009 | 10:33 PM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
yes, low voltage will cause a check engine light... it's off now
To awesome... Check Engine Light
