shorty headers????
Old Oct 19, 2009 | 04:36 PM
sweet97c5's Avatar
sweet97c5
Default shorty headers????
How big of a diff. in power gain is it from long tubes and shorty headers?
Old Oct 19, 2009 | 05:33 PM
1FUNVTT's Avatar
1FUNVTT
Long tubes will probably get you about 5-10% HP gain. Shorties will be around 5-10 HP. But if you live in CA, long tubes are not smog legal (visual test) and the shorty tubes (like from B&B = CARB # issued) are smog legal. Shorty headers are also lighter than your OEM exhaust manifold, if you're counting lbs.
Old Oct 19, 2009 | 10:01 PM
sweet97c5's Avatar
sweet97c5
thanks for info.I'm on tight budget and shorties are much cheaper.
Old Oct 19, 2009 | 10:55 PM
99vetteran's Avatar
99vetteran
Kooks makes a great short tube or they may call them midtubes with high flow cats. I've go the long tubes on my 99vette, no cats. Then on my 08' g8gt I've got the midtube kooks with hiflow cats. I like them both.
Old Oct 19, 2009 | 11:04 PM
lucky131969's Avatar
lucky131969
Even more the reason to spend your money wisely.........
Old Oct 19, 2009 | 11:55 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
My thoughts EXACTLY! Save your cash until you can afford a real exhaust! You will be MUCH happier!!!
Old Oct 20, 2009 | 11:36 AM
hotwheels57's Avatar
hotwheels57
No argument about waiting to get the right equipment. Be patient and do it right the first time. However...
Does your state have strict emissions requirements? The B&B are CARB approved. Long tube headers are not approved.
What are your goals? Is it strictly for looks or sound, the cool factor, more power, cooler engine compartment, less weight on the front end? Is your engine otherwise stock? Do you have plans to leave it stock or heavily modify it more in the future? Consider that with each performance improvement, you'll probably need to consider other areas in the future, such as heads, cam, air/fuel intake, gears, bottom end, transmission/rear end work, additional tune(s), etc. Maybe even bigger headers. It never ends.
Figure out what shorty headers will cost you. Look at both used and new costs. You can probably install them yourself, without having to modify the rest of your exhaust system. You won't need to spend more money on a tune. Their benefits are similar to long tubes, except w/o the higher performance increase. Your engine compartment will still look better, run more efficiently than with cast iron manifolds, improved sound, and much less weight on the front end.
Now figure out what long tube headers will cost you. Look again at both used and new costs, including installation if you can't do it yourself. Consider the cost of modifying your remaining exhaust if that's necessary with what system you chose. Include the cost of a tune to achieve optimum results for your efforts and expense.
And with any performance increases, have you adversely effected the reliability and driveability of your car after the changes.
People love to spend your money...
To shorty headers????
