TPIS Headers leaking......(HELP)
Old Feb 25, 2002 | 10:48 AM
97C5ENVY's Avatar
97C5ENVY
Default TPIS Headers leaking......(HELP)
My TPIS Headers are leaking at the collector. And i know it's due to the TPIS supplied "H" pipe not being pushed all the way into the collector. But my problem is that every time i do push it all the way in it eventually works it's way loose again. I've had the headers for about 6 months prior to my MTI H/C and Z06 leaf spring additions and never had this problem before. So, i assume it's coming loose due to the vibration of the motor and the stiffer ride from the Z06 springs.
So what can i do to keep the darn "H" pipe from coming out that isn't a permenent fix (ie. welding)? Thanks!
Old Feb 25, 2002 | 11:25 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: TPIS Headers leaking......(HELP) (97C5ENVY)
I had my setup tac welded so it does not move. They can easily grind off a small tac weld if they need to remove your system. :cheers:
vetterdstr :chevy
Old Feb 25, 2002 | 12:24 PM
C5Noir's Avatar
C5Noir
Yep, put in a taq weld. It'll hold it in place. That's how I fixed mine :D
To TPIS Headers leaking......(HELP)
