Question about separating Tranny from Tq-Tube
Old Oct 22, 2009 | 02:02 PM
97C5ENVY's Avatar
97C5ENVY
Default Question about separating Tranny from Tq-Tube
What's the "common practice" when separating Tranny from Tq-Tube: (1) Do you disconnect the shifter-rod at the shifter and slide the tranny and shifter rod as a single unit apart from the Tq-Tube; or (2) Do you disconnect the shifter rod at the Tranny and then searate the two units?
Old Oct 22, 2009 | 02:23 PM
argonaut's Avatar
argonaut
#1 - pull the shifter out of the TT entirely. Then do the separation and the rod will come right out, still attached to the tranny.
Old Oct 22, 2009 | 03:14 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
T40 to disconnect at the shifter and then remove the 13mm bolts holding the tranny to the torque tube.
To Question about separating Tranny from Tq-Tube
