From a Fast90 to LS2 intake question
Old Oct 19, 2009 | 11:02 PM
jmoody66's Avatar
jmoody66
Default From a Fast90 to LS2 intake question
Ok so I have a goal of 12 to 14 lbs of boost...maybe more so I sold my Fast 90 and got a ported LS2. I go to install it and my LS6 stock fuel rail will not bolt right up. My assumption is that I have to upgrade to either an LS2 stock setup or just go all out and get an aftermarket fuel rail setup.
Need opinions on least expensive route where pimpin looks doesnt matter...I just want the performance.
Old Oct 20, 2009 | 01:02 AM
Mike94ZLT1's Avatar
Mike94ZLT1
Get a TPIS modified LS6 intake with a 90MM snout. Flows better, and uses your stock fuel rails. Selling your FAST should cover the cost of one.
Old Oct 20, 2009 | 01:10 AM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
I think they make a kit (small spacers) to make the LS1/LS6 fuel rails fit on.
Old Oct 20, 2009 | 01:50 AM
geocor2003's Avatar
geocor2003
Hmmm,was going to get a fast 92.Lot of documentation backing your claim up?
Old Oct 20, 2009 | 08:52 AM
Mike94ZLT1's Avatar
Mike94ZLT1
I'm not saying a TPIS intake outflows a FAST intake, however they are close and bang for the buck the TPIS intake is a better value. It does however flow significantly better than an LS2 manifold.
Old Oct 20, 2009 | 08:55 AM
AU N EGL's Avatar
AU N EGL
I run an older TPIS ported 78tb on the LS6intake. Very happy with the power and torque produced.
Many guys who road race chose this set up for power and torque vs the Fast products
Old Oct 20, 2009 | 03:13 PM
zeevette's Avatar
zeevette
The problem is, sounds like he already has the LS2 mani setup. For a FI install, the intake manifold will make very little difference. If the mounting tabs line up, just get spacers to clear the runners, and use your LS6 fuel rail. If not, maybe you can bend/redrill them to fit.
Old Oct 22, 2009 | 03:19 PM
jmoody66's Avatar
jmoody66
Default setup
Yes I already regretfully sold my ported Fast 90 due to my wanting to up the boost and I forgot to mention that I had the motron 60lb injectors and yes I already got the LS2 ported unit. Ive already purchased the proper fuel rails capable of supporting 1k hp and all the supporting hardware so hopefully next week I will be up n running. Thanks for all the input guys.
To From a Fast90 to LS2 intake question
