What connect's to this ?
Old Oct 22, 2009 | 06:19 PM
Juliano's Avatar
Juliano
Cruising
Default What connect's to this ?
this is on the inside of my hood front left hand side but noting is connected to it, should there be ?
Old Oct 22, 2009 | 06:29 PM
Juliano's Avatar
Juliano
Cruising
Default Here is something else too!!
Another mystery? i found this just under and behind my alternator, and the plug does not look like it belongs there !!
Old Oct 22, 2009 | 08:30 PM
byronhunter's Avatar
byronhunter
Juliano, is this a test, put that camera up, and save for a good day!
First pix is just the head of one of the bolts that hold the cradle on the bottom. Second is a Temp Sensor, with part of the housing broken off.
Old Oct 22, 2009 | 08:35 PM
lucky131969's Avatar
lucky131969
on a side note......based on the pictures, and the amount of corrosion...I would be taking a look at those grounds
Old Oct 22, 2009 | 10:27 PM
Juliano's Avatar
Juliano
Cruising
Take a look at it how? should i replaced it ?
Old Oct 22, 2009 | 11:01 PM
byronhunter
Lucky is advising cleaning Grounds like this. Take it loose, remove top cover, clean all contacts and apply some Dielectric greese to it.
Old Oct 22, 2009 | 11:15 PM
lucky131969
Yep, and replace that coolant temp sensor....eventually that will work it's way off.
Did you just buy this car or what?
Old Oct 23, 2009 | 12:01 AM
Juliano's Avatar
Juliano
Cruising
Yes i just bought it, and i know " 0 " about them so excuse me for not knowing, I will take you guys advise and replace that sensor and also clean off the ground where it's pointed out on the picture Thank you guys again...
Old Oct 23, 2009 | 02:53 AM
memphis_vette's Avatar
memphis_vette
there are more than just the one connector to clean. someone should post the schematics for it.
Old Oct 23, 2009 | 08:09 AM
Juliano's Avatar
Juliano
Cruising
What !! theres more of these to clean, where are they?
Old Oct 23, 2009 | 08:39 AM
lucky131969
Relax. Read the electrical sticky at the top of the tech section. Salvation lies within.
Old Oct 23, 2009 | 08:53 AM
blazer427X3's Avatar
blazer427X3
[QUOTE Salvation lies within.[/QUOTE]
Lots of good info in that sticky being referred to. It will tell you the location of all the grounds. Congrats on the Vette !
Old Oct 23, 2009 | 02:01 PM
bobby777's Avatar
bobby777
Looks like a 100,000 mile vette-scary
Old Oct 23, 2009 | 03:39 PM
byronhunter
You base that statment on what?
Old Oct 23, 2009 | 04:09 PM
LoneStarFRC's Avatar
LoneStarFRC
I've got over 150,000 miles and that area on mine doesn't look anything CLOSE to that.
Maybe you should be looking at that being an Illinois car. Can you say "road salt" or "road chemicals"?
To What connect's to this ?
