How does aligning the shifter work?
Old Oct 27, 2009 | 03:58 PM
ZONick's Avatar
ZONick
Default How does aligning the shifter work?
I talked to RPM about my notchey transmission and they said to align the shifter as I've heard before. He said that since i didn't have a neutral lock pin just put a drill bit in there (5/32 fit nicely), loosen the other bolts, then tighten them. As I expected this didn't change a thing and I don't get how it would...
You are moving hte shfiter body forward and back, but leaving hte rod/linkage in the same place. Basically if you push it back more your shifter will sit a bit more angled than before and opposite angle with forward. I don't get how changing this can make any difference to how nothcy the transmission feels.
I tried moving it all the way up, all the way back, and aligned according to the neutral lock hole and they all felt exactley the same.
What's the deal here?
Old Oct 27, 2009 | 04:37 PM
lucky131969's Avatar
lucky131969
Done correctly, the transmission is placed in neutral first:
Old Oct 27, 2009 | 04:52 PM
ZONick's Avatar
ZONick
Yes it was in neutral. I'm not sure you can align it any other way. I get the directions, but I don't get how it actually works, especially since it didn't for me.
Old Oct 27, 2009 | 05:06 PM
lucky131969
Well, if you get the directions, but don't get how it works...then you don't get the directions......
There are two fixed items:
1) The shifter itself, held in the neutral position by the locking pin.
2) The tranny linkage (placed in neutral).
The variable is the shifter housing, which has slotted mounting holes. The shifter is held in a constant position(neutral), and must maintain that relationship with the neutral position of the linkage. The slotted holes in the housing make up for any tolerances in the torque tube, and shift housing.
Old Oct 27, 2009 | 06:02 PM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
With everything loose and the lock pin/drill bit engaged you can grab the shift rod and spin and move it slightly to alligne it perfectly with the bolt hole that clamps it to the shifter body... very small movements there make huge differences in how the shifter behaves.
Old Oct 27, 2009 | 07:43 PM
ZONick's Avatar
ZONick
Well I meant I get what RPM told me to do which is simply put the neutral lock pin in, loosen everything, then tighten it all.
If I am understanding correctly you are saying to put the nuetral pin in, loosen everything, pull out the back bolt that connects to the clamp and the rod, spin/move the shift rod (the part that connects to the tranny not the shifter) until it lines up perfectly (doesn't the bolt force it to be perfect?), then tighten everything back up?
I may try and pull it apart one more time. I have already pulled it apart the past 2 nights and I can probalby do the whole thing in like 20 minutes now lol.
Old Oct 27, 2009 | 08:13 PM
tstar's Avatar
tstar
You've got it... and no the "pinch" bolt doesn't force it into perfect allignement, there's some slop in there probably for variables between cars on the assembly line.
You'll be the Forum shifter allignement expert before this is all done...
Tim
Old Oct 27, 2009 | 08:27 PM
JropTop's Avatar
JropTop
LMAO,Ive ben following your replies as i find them very knowledgable,no matter what the question is,but you always crack me up with some of your remarks!
Old Oct 27, 2009 | 08:32 PM
ZONick's Avatar
ZONick
Old Oct 27, 2009 | 09:21 PM
lucky131969
I would definitely try the c6 shifter before going any further.
Old Oct 28, 2009 | 03:52 AM
tstar's Avatar
tstar
And some good quality Synthetic Tranny fluid...
To How does aligning the shifter work?
