P 1631 AND B 2721. PASS Key and Theft deterrent. Help!
My car is stuck in my driveway luckily. I went home the other day and it didn't fire right up, gave me nothing at all when I turned the key...showed a code that had to do with the key theft deterrent system, so I sprayed the key with electrical cleaner and wiped it off. Then wiped it with an eraser, went back outside and it started right up.
Just 45 mins ago I ran home again and went back out and she didn't start this time...
The codes are B 2721 PASS-KEY DETECTION CIRCUIT
AND
P 1631 THEFT DETERRENT START ENABLE SIGNAL NOT CORRECT
What do I have to fix now?
Thanks so much for any help,
Donnie
There's pretty much no way that the key pellet can break I guess, mine isn't loose and it's clean. So that eliminates that.
Should I start looking to the theft deterrent relay or the relay that is above the BCM?
Should I be looking at my lock cylinder or ignition system itself?
Please anyone, help me out here lol.
Donnie
Donnie
Received 8,928 Likes
I would start by cleaning the contacts in the lock cylinder. From there it gets a little more involved. The P1631 code is generated when the BCM sends an incorrect password to to the PCM. The B2721 code issue has to be resolved before you can work on this one. Once you solve PassKey issue the other may just go away. If cleaning the contacts in the lock cylinder doesn't help then you may have a wiring problem in the resistance sensing circuit between the BCM and the cylinder, a bad BCM or a bad lock cylinder. Doubtful the theft relay is bad. It is just doing what the BCM is telling it to do.
Bill
Bill
Bill,
Thank you for the suggestions. How do I go about cleaning the inner lock cylinder? Should I pull it apart or just spray something up in there?
I'll start with that and disconnecting the battery, I get off work in about 30 minutes. So within an hour and half I'll be home and have the first two steps done lol.
Thanks again and I'll check back frequently.
Donnie
Donnie
I would spray something in the cylinder and then move the key in and out to help clean the contacts.
Bill
Bill
Bill,
Thanks so much for your help! I got it going again, just sprayed the cleaner in the cylinder like you said and wiggled the key around.
Fired up no problem, codes went away and security light turned off.
I might eventually have to get the new cylinder but for now, thank you som much once again!
Donnie
Donnie
Similar symptoms and codes see my post on page 1
If you read my post H E L P ! ! ! Turn key in ignition NOTHING you will see I had these codes and a few others but essentually the car would not start. Do you think you have solved the problem or are you keeping your auto insurance towing number in your hip pocket like me? BIGHANK
Used contact cleaner in ignition switch
I spreyed contact cleaned in the ignition switch and worked the keys in and out. Car restarted several times without any codes. Not sure that I have fixed the problem. BIGHANK
