Code P0410
Old Oct 29, 2009 | 06:56 AM
540 vette's Avatar
540 vette
Default Code P0410
How does this system work and where are the components of it and what usually goes wrong with it.
The code came up yesterday as I was driving home from work in heavy rain. Could the rain have triggered it. I read on the OBD 2 site that water in the pump will cause the code.
And yes I did a search.
Old Oct 29, 2009 | 02:11 PM
540 vette's Avatar
540 vette
ttt
Old Oct 29, 2009 | 07:50 PM
540 vette's Avatar
540 vette
This is the first time the code came up.
I was driving on the parkway when the check engine light came on. And like I said before it was raining.
Old Oct 30, 2009 | 01:59 PM
FASST LN's Avatar
FASST LN
If you run a search, you should find my thread with this same problem code. For my situation, the battery had leaked acid and some had gotten on the vacuum line running from the battery area to the air pump, eating a hole in the line. This prevented the vacuum pressure from building and turning on the air pump. I replaced the battery, cleaned up the mess, and replaced the vacuum line. Voila! Everything has worked fine since.
Old Oct 30, 2009 | 02:08 PM
540 vette's Avatar
540 vette
Except my battery never leaked acid.
Old Oct 30, 2009 | 02:25 PM
KPSquared's Avatar
KPSquared
My car had this code. I sort of ignored it because I didn't need to have an emissions test in Kentucky. Well, I'm in Iraq now and my wife had to tag the car in Atlanta, GA. Needed a new air pump and both check valves replaced. $1,200. She drove the car for a week then got it tested. It passed.
She put it in the garage and there it will stay until I come back (she hates the car). She said I was lucky...if it wouldn't have passed she said she was going to trade it in for some Kias.
Old Oct 31, 2009 | 01:10 PM
540 vette's Avatar
540 vette
Cleared the codes and took the car out to get gas, no codes, no check engine light
Old Oct 31, 2009 | 01:27 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
This code will only show if the fuel level more than 12.5 percent and less than 87.5 percent. I have a feeling if you drive awhile it's going to come back.
Old Oct 31, 2009 | 10:10 PM
540 vette's Avatar
540 vette
unless I keep the gas at 3/4's
drove it 40 miles today, no code.
Old Nov 1, 2009 | 03:10 PM
Bill Dearborn's Avatar
Bill Dearborn
DTC P0410 Secondary Air Injection (AIR) System
Circuit Description
An AIR pump is used on this vehicle to lower tail pipe emissions on start-up. The PCM supplies a ground to the AIR pump relay, which energizes the AIR pump.
The PCM monitors the HO2S voltages to diagnose the AIR system.
During the AIR test, the PCM activates the AIR pump during closed loop operation. When the AIR is activated, the PCM monitors the HO2S voltages and short term fuel trim values for both banks of the engine. If the AIR system is operating properly, the HO2S voltages should go low and the short term fuel trim should go high.
If the PCM determines that the HO2S voltages for both banks did not respond as expected during the tests, DTC P0410 sets. If only one sensor responded, the PCM sets either a DTC P1415 or P1416 to indicate on which bank the AIR system is inoperative.
Conditions for Running the DTC
  • DTCs P0101, P0102, P0103, P0107, P0108, P0112, P0113, P0117, P0118, P0125, P0171-P0175, P0200, P0300, P0335, P0336, P0351-P0358, P0440, P0442, P0443, P0446, P0449, P1120, P1220, P1221, P1258, P1441 and HO2S DTCs are not set.
  • The engine is running for greater than 2.0 seconds.
  • The maximum air flow is 22 g/s.
  • The Air Fuel ratio is 14.7:1
  • The engine load is less than 40%.
  • The ignition voltage is greater than 11.7 volts.
  • Engine is not operating in Power Enrichment, Decel Fuel Shut-off, or Catalyst Over-temperature Modes.
  • The engine is operating in closed loop for greater than 15 seconds.
  • The engine speed is greater than 725 RPM.
  • The ECT is greater than 80°C (176°F) but less than 110°C (230°F).
  • The IAT is greater than -10°C (-14°F).
  • The fuel system is operating in fuel trim cells 1, 2, 4, 5, or 6
Conditions for Setting the DTC
The HO2S voltage does not go below 222 mV for 1.2 seconds, when the AIR pump turns ON during closed loop operation.
OR
The short term fuel trim does not change more than a predetermined value, when the AIR pump turns ON during closed loop operation.
Action Taken When the DTC Sets
  • The PCM illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
  • The PCM records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the PCM stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the PCM records the operating conditions at the time of the failure. The PCM writes the conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
  • The PCM turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
  • A last test failed, or current DTC, clears when the diagnostic runs and does not fail.
  • A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
  • Use a scan tool in order to clear the MIL and the DTC.
Diagnostic Aids
Important
  • Remove any debris from the PCM\TAC module connector surfaces before servicing the PCM\TAC module. Inspect the PCM\TAC module connector gaskets when diagnosing/replacing the modules. Ensure that the gaskets are installed correctly. The gaskets prevent contaminate intrusion into the PCM\TAC modules.
  • For any test that requires probing the PCM or a component harness connector, use the Connector Test Adapter Kit J 35616-A . Using this kit prevents damage to the harness/component terminals. Refer to Using Connector Test Adapters in Wiring Systems.
AIR Pump Relay Underhood Electrical Center Terminal Identification
=====================Front of Vehicle
Left Side of Vehicle=======Ignition===B+=====Right Side of Vehicle
=====================Load===Control
AIR Solenoid Relay Underhood Electrical Center Terminal Identification
========================Front of Vehicle
Left Side of Vehicle========Ignition===Load=====Right Side of Vehicle
======================B+=====Control
  • Using Freeze Frame and/or Failure Records data may aid in locating an intermittent condition. If you cannot duplicate the DTC, the information included in the Freeze Frame and/or Failure Records data can aid in determining how many miles since the DTC set. The Fail Counter and Pass Counter can also aid determining how many ignition cycles the diagnostic reported a pass and/or a fail. Operate the vehicle within the same freeze frame conditions (RPM, load, vehicle speed, temperature etc.) that you observed. This isolates when the DTC failed.
  • For an intermittent, refer to Symptoms .
Test Description
The numbers below refer to the step numbers on the diagnostic table.
Step 2. If DTCs P0412 or P0418 are set, diagnose those DTCs first.
Step 4. This step is testing for battery voltage at the AIR pump relay and the AIR solenoid relay. If voltage is not present at both of the AIR relays the AIR system does not operate properly.
Step 5. The scan tool offers three modes of AIR operation, AIR solenoid, AIR pump, and AIR system. Use the AIR system selection when commanding the AIR pump, or relays. This mode ensures that the entire AIR system is responding to the scan tool commands. If DTCs P0412 or P0418 are not set and the relays do not respond to the scan tool commands, inspect for excessive resistance in all of the circuits associated with the AIR system.
Step 6. This step is testing for power to the AIR pump.
Step 7. This step is testing the ground circuit for the AIR pump.
Step 10. A restriction in a hose or pipe before the systems divides will cause this DTC to set. Inspect for kinks or blockages from the AIR pump to the connection point where the AIR system divides.
Step 12. This step is testing for a grounded circuit between the AIR pump and the AIR pump relay.
Step 13. This step is testing for a grounded circuit between the AIR pump and the AIR solenoid relay.
DTC P0410 - Secondary Air Injection (AIR) System
Step
Action
Value(s)
Yes
No
Step 1
Did you perform the Powertrain On-Board Diagnostic (OBD) System Check?
Go to Step 2
Go to Powertrain On Board Diagnostic (OBD) System Check
Step 2
Are DTCs P0412 and/or P0418 set?
Go to Applicable DTC table
Go to Step 3
Step 3
Is the AIR pump fuse OK?
Go to Step 4
Go to Step 11
Step 4
  • Turn OFF the ignition.
  • Disconnect the following components:
    • The AIR pump relay.
    • The AIR solenoid relay.
  • Probe both relay B+ supply circuits at the underhood electrical center using the test lamp J 34142-B connected to ground. Refer to Diagnostic Aids for terminal identification.
Does the test lamp illuminate for both terminals?
Go to Step 5
Go to Step 16
Step 5
  • Install both relays.
  • Turn ON the ignition leaving the engine OFF.
  • Enable the AIR system using a scan tool.
Does the AIR pump turn ON?
Go to Step 8
Go to Step 6
Step 6Is the test lamp illuminated?
Go to Step 7
Go to Step 17
Step 7
Probe terminal C of the AIR pump electrical connector using the test lamp J 34142-B connected to B+.
Go to Step 25
Go to Step 18
Step 8Is air flow present at the AIR pump outlet?
Go to Step 10
Go to Step 9
Step 9
  • Disconnect the AIR pump electrical connector.
  • Probe terminal B of the AIR pump electrical connector using the test lamp J 34142-B connected to battery ground. Refer to Probing Electrical Connectors in Wiring Systems.
Go to Step 25
Go to Step 19
Step 10
  • Inspect for a restriction/blockage or a disconnect in the AIR hoses/pipes between the AIR pump and the point where the system branches to both sides of the engine.
  • If you find a restriction/blockage or a disconnect in the AIR hoses/pipes, repair as necessary.
Is the action complete?
Go to Step 27
Step 11
  • Probe both relay B+ supply terminals at the underhood electrical center using the test lamp J 34142-B connected to B+. Refer to Probing Electrical Connectors in Wiring Systems. Refer to Diagnostic Aids for terminal identification.
Go to Step 20
Go to Step 12
Step 12
  • Disconnect the AIR pump electrical connector. Refer to Secondary AIR Injection Pump Replacement .
  • Probe the AIR solenoid relay load terminal at the underhood electrical center using the test lamp J 34142-B connected to B+. Refer to Diagnostic Aids for terminal identification.
Does the test lamp illuminate?
Go to Step 21
Go to Step 13
Step 13
Probe the AIR pump relay load terminal at the underhood electrical center using the test lamp J 34142-B connected to B+. Refer to Diagnostic Aids for terminal identification.
Go to Step 22
Go to Step 14
Step 14
  • Install the AIR pump electrical connector.
  • Install a new fuse.
  • Install the AIR pump relay.
  • Enable the AIR system using the scan tool.
Does the fuse open?
Go to Step 26
Go to Step 15
Step 15
  • Install the AIR solenoid relay.
Does the fuse open?
Go to Step 26
Go to Diagnostic Aids
Step 16
Repair the open circuit that did illuminate the test lamp. Refer to Wiring Repairs in Wiring Systems.
Go to Step 27
Step 17
  • Test for continuity of the circuit between the AIR pump electrical connector terminal A and the AIR pump relay using the DMM J 39200 . Refer to Testing for Continuity in Wiring Systems.
  • If you find an open circuit repair the circuit as necessary. Refer to Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 27
Go to Step 23
Step 18
Repair the faulty ground connection or open AIR pump ground circuit. Refer to Wiring Repairs in Wiring Systems.
Go to Step 27
Step 19
  • Test for continuity between the AIR pump electrical connector terminal B and the AIR Solenoid relay using the DMM J 39200 . Refer to Testing for Continuity in Wiring Systems.
Go to Step 27
Go to Step 24
Step 20
Repair the short to ground in the ignition feed circuit between the fuse and the relays. Refer to Wiring Repairs in Wiring Systems.
Go to Step 27
Step 21
Repair the short to ground in the circuit between the AIR Solenoid relay and the AIR pump. Refer to Wiring Repairs in Wiring Systems.
Go to Step 27
Step 22
Repair the short to ground in the circuit between the AIR pump relay and the AIR pump. Refer to Wiring Repairs in Wiring Systems.
Go to Step 27
Step 23
Replace the AIR pump relay. Refer to Secondary Air Injection Pump Relay Replacement .
Go to Step 27
Step 24
Replace the AIR solenoid relay. Refer to Secondary Air Injection Solenoid Relay Replacement .
Go to Step 27
Step 25Did you find and correct the condition?
Go to Step 27
Go to Step 26
Step 26
Replace the AIR pump. Refer to Secondary AIR Injection Pump Replacement .
Go to Step 27
Step 27
  • Select the Diagnostic Trouble Codes (DTC) option and the Clear DTC Information option using the scan tool.
  • Idle the engine at the normal operating temperature.
  • Select the Specific DTC option under the Diagnostic Trouble Code (DTC) option using a scan tool.
  • Operate vehicle within the Conditions for Running this DTC as specified in the supporting text, if applicable.
Does the scan tool indicate that this test failed?
Go to Step 2
Go to Step 28
Step 28
Select the Capture Info option and the Review Info option using the scan tool.
Are any DTCs displayed that you have not diagnosed?
Go to the applicable DTC table
System OK
Bill
Old Nov 1, 2009 | 08:00 PM
540 vette's Avatar
540 vette
Thanks Bill.
To Code P0410
