Problem with LS1 to LS3 upgrade
Old Nov 16, 2009 | 04:34 AM
goa2head's Avatar
goa2head
Originally Posted by dgrant3830
Well, give us more detail if it was the PCM. Did you have to replace it or was a connector not seated all the way?
I opened the PCM and did find a lot of moisture. Cleaned it up/sealed it and tryed again, and all the codes was gone and now I have driven/tested the car all day yesterday without any problems.
Old Nov 16, 2009 | 01:25 PM
chaase's Avatar
chaase
St. Jude Donor '12
If I were the owner I would be hesitant about keeping that PCM, but at least the car is running again. Moisture inside the PCM is not good. I am not an expert, but if I were the owner I would consider getting a new PCM as it sounds like that was a flood car.
