Vibration when hot
Old Oct 31, 2009 | 06:10 PM
omegac1's Avatar
omegac1
Default Vibration when hot
I have a new to me automatic 2003 with 80K miles. I have noticed that when the engine is hot (water 210 and tranny fluid 210) that there is a vibration wether the car is moving or not. The vibration seems to be in the frame (you can feel it in the sesat of your pants)and is the frequency of the engine...speed up the revs and the vibation speeds up....this is with the car standing still. I am new to the corvette so I am looking for ideas?
Old Oct 31, 2009 | 06:49 PM
Nick F's Avatar
Nick F
Could just be normal, these cars have big engines. There's a lot of weight slinging around in there. Mine vibrates a little too.
Welcome. Hope there's no issue with your vette!
Old Oct 31, 2009 | 06:55 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Well, start by pulling your codes to see if anything is showing up there in case this is a cylinder misfiring. Do you notice any hesitations from the car or anything to indicate there is a problem other than the description? Unusual sounds from the exhaust? Poor gas mileage?
Old Oct 31, 2009 | 07:13 PM
ZeeOSix's Avatar
ZeeOSix
Look at the crank damper while the engine is running and see if it's running true. Look for any wobbling.
Old Oct 31, 2009 | 09:00 PM
omegac1's Avatar
omegac1
The engine seems to be running great...no codes..no misses, etc. Its almost like a "rubbing" sound and feel instead. Again only when hot. I will check the damper that is a good idea.
Old Nov 2, 2009 | 07:32 AM
omegac1's Avatar
omegac1
bump
Old Nov 3, 2009 | 12:11 PM
dgrant3830's Avatar
dgrant3830
Find anything yet? With it being rpm related, the fan belts, idlers and balancer are all suspect. You might want to take the serpentine belt and AC belt off and spin things manually.
Old Nov 3, 2009 | 10:51 PM
Carcass's Avatar
Carcass
If everything else checks out ok,jack it up,pull the inspection plate,fire it up,and see if the flex plate has a "wobble"after it warms up.
They have been known to crack from time to time...
To Vibration when hot
