Hesitation Under Load. Backfires.
Old Nov 2, 2009 | 11:31 PM
dbirdz06's Avatar
dbirdz06
Default Hesitation Under Load. Backfires.
I took my car in for a dyno tune 2 weeks ago and had problems on the dyno. It was throwing Traction Control, ABS, and Active Handling codes at WOT on the dyno. My car has a mild cam (228/230 112lsa), headers, and a Vararam. Nothing crazy. I've had it like this for about 2 years with another dyno tune and no major WOT problems.
Here's what the dyno looked like from 2 weeks ago:
I have since replaced the clutch because my slave cylinder was leaking and took the car out to test it. The car idles fine, takes off fine, but putting any load on the car will cause it to stumble and hesitate. It will even backfire! For the most part it still has good power but is very inconsistent.
The codes I had were C1221 and C1222 and C1248. I reset these earlier today and they have not come back on.
I read that it was a good idea to check the ground wire plugs. Did that tonight. They looked ok but I rubbed the connection with some sandpaper for good measure. NOW, my headlights won't go down!!
I don't know what to do. Any suggestions would be much appreciated.
Old Nov 3, 2009 | 08:13 AM
dbirdz06's Avatar
dbirdz06
I took it to work this morning. Somehow magically the headlights went down on their own at some point overnight
Car will still backfire occasionally. I start noticing the problem at highway speeds. I can be cruising in 6th at 60-70 and give it half or so throttle and it will start to hesitate and bog down. Doing this will cause it to backfire occasionally.
No codes at all, no warnings, nothing.
Could it be something simple like a bad spark plug or wire? Wouldn't that throw codes?
Need some help please!
Old Nov 3, 2009 | 09:01 AM
11sec_C5Z51's Avatar
11sec_C5Z51
Mine did the same on two different occasions. Once the culprit was a fouled spark plug and on the other occasion, it was a faulty 02 sensor.
Old Nov 3, 2009 | 09:57 AM
lucky131969's Avatar
lucky131969
Since you had your car at a tuner, and he had the ability to read all the sensors in real time, what feedback did he provide on the cause? What is the history with the car, and when did this start exactly? What is your fuel pressure? Have you inspected the AIR connections for security and leaks?
You said you examined the plugs, I hope the sandpaper was not used on the electrode.......
Old Nov 3, 2009 | 11:04 AM
dbirdz06's Avatar
dbirdz06
Did your car show a check engine light or throw any codes?
Old Nov 3, 2009 | 11:09 AM
dbirdz06's Avatar
dbirdz06
The tuner's feedback indicated that the TC, AH, & ABS were all acting up on the dyno during WOT. You could see the car jerking around on the dyno during the pull and you could start to smell hot brakes.
As far as the history of the car, I've had this cam in for over 2 years with an OK tune that did not cause any problems. Maybe it was just a coincidence that it happened on the dyno with a new tune.
I did find a loose wire in the front passenger side O2 sensor plug while I was swapping my clutch this weekend. I pushed it back in and it stayed, but that didn't change anything. Could be a good place to start.
The sand paper was not used on the spark plugs, just on the ground connections to the frame.
Not sure what my fuel pressure is, but I have replaced my fuel filter within the last 6 months.
Old Nov 3, 2009 | 12:22 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
In regards to the dyno run, I'm not an expert or anything similar but, the PCM looks at the wheel speed sensors in comjunction with the EBTCM and so on all making determinations if the wheels are turning as expected. So on the dyno, hopefully you turned off the AH/TC systems otherwise they will indeed try to put on the brakes and so on due to the front wheels not moving and the rears are. This would throw codes like crazy for those systems and induce lots of engine control issues. If I missed something you said, feel free to tell me to be quiet...lol
Old Nov 3, 2009 | 12:29 PM
rebelheart's Avatar
rebelheart
I also wondered why the traction control was even on during dyno pulls! A good tuner should have known better.Makes me think perhaps your tune may be out of whack also.
Old Nov 3, 2009 | 12:32 PM
lucky131969
Sounds like a slipping clutch......
If the pin lock is broken, the connector needs to be replaced.
I'm really suprised your tuner was not able to provide more insight.
Old Nov 3, 2009 | 01:35 PM
dbirdz06's Avatar
dbirdz06
The AH/TC was turned off for the dyno pull, but it would still activate and show error messages on the DIC. It was almost as if it would come back on by itself.
Old Nov 3, 2009 | 01:41 PM
dbirdz06's Avatar
dbirdz06
A slipping clutch was one of my thoughts at the time too b/c I had a leaking slave. This was the main reason I swapped clutches this weekend. That should at least take that portion out of the equation.
I'm not sure what pin lock are you talking about? The wire that was pulled out was part of the male connector of the wiring harness that leads up to the engine, not part of the O2 sensor itself. I shoved it back in and it held snug, but it's possible that it's not getting a good connection. What is involved with replacing this? Does GM sell these plugs/connectors or do I have to trace the wiring harness back to the computer?
I think my first step tonight is to swap out the plugs with some new TR55's. If that doesn't do the trick, then wires. If not that, then the O2 plug.
After that it's back to the tuner.
Not sure what else it could be.
Old Nov 3, 2009 | 02:08 PM
lucky131969
There is a small lock in an electrical connector that holds the pin(or socket) in place in the connector body. If the wire pushes out the back of the connector...when plugged in, it suggests that the lock is not working..or damaged. Different connectors uses different methods, some locks are on the pin/socket itself, while others have the lock incorporated into the connector body.
Old Nov 3, 2009 | 02:16 PM
lucky131969
I know you said the traction control was off during the dyno run, but is there a chance the tuner forgot initially?
The codes you posted are consistent with the system sensing two wheels moving(on the same axle), in conjunction with two wheels stationary(on the same axle). A C1221 & C1222 will precipitate a C1248.
Old Nov 3, 2009 | 02:43 PM
dbirdz06's Avatar
dbirdz06
I'm positive that the system was disabled prior to the dyno run. Since I reset the 1221 & 1222 codes, they have not come back on since driving the last 2 days.
Old Nov 3, 2009 | 03:40 PM
lucky131969
Did you actually run the car on the dyno?
Old Nov 3, 2009 | 04:22 PM
dbirdz06's Avatar
dbirdz06
When I took it in for a dyno tune 2 weeks ago, the tuner had it on the dyno. That graph is on my first post.
The tuner and I talked about the traction control issues. He purposefully turned off the TC/AH and it would still throw warnings during the pull.
Old Nov 3, 2009 | 04:31 PM
lucky131969
ok. I guess the codes are just a coincidence.
To Hesitation Under Load. Backfires.
Old Nov 3, 2009 | 06:02 PM
dbirdz06's Avatar
dbirdz06
Your guess is as good as mine! I wish I knew.
Hopefully I can track this down.
Old Nov 3, 2009 | 10:22 PM
dbirdz06's Avatar
dbirdz06
Replaced the plugs and wires. So far the problem has been resolved!
Old Nov 3, 2009 | 11:49 PM
lucky131969
Nice.
