considering a DIY diff change
Old Nov 1, 2009 | 08:52 PM
Toby Van Horn's Avatar
Toby Van Horn
Default considering a DIY diff change
I am considering a do it yourself diff change. I have a M/T and want to go to a 3.42 rear diff as mine was changed to 2.73.
Earlier this year I did valve springs on this car, I have done clutches ect in other cars, but am a little scared of the rear diff / torque tube ect.
Any stories / insight would be great.
Toby
Old Nov 1, 2009 | 10:53 PM
waddisme's Avatar
waddisme
Go to cajundude.com and he has a detailed diy with pics that should pretty much let you know if you want or not. I am in the middile of repl a pilot bearing so diff had to come out. A lot of stuff, but nothing hard. Good luck.
Old Nov 1, 2009 | 10:58 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
It is not a hard job. I've done it a few times. The hardest part is getting over the idea that you've got to drop the entire cradle out from under the car. It can be a little intimidating but don't let it be. You do need to be aware of the electrical connections on top of the diff and trans as you lower it down.
It's about a 4-5 hour job on jack stands. Less, if you have a lift.
Old Nov 2, 2009 | 04:12 AM
Z06supercharged's Avatar
Z06supercharged
Dropping it all is a piece of cake. I did it first time last week by myself with air tools (a must have) on jackstands and I bought as $79 tranny jack from Harbor Freight which made it very easy.
I dropped cradle separately from the rest cause its easier in my opinion that way especially when your trying to put the TT/trans/diff back into the clutch as 1 unit. I also changed the trans/diff fluids while they were on my tranny jack on the ground which was much easier than doing it later back installed.
Console out and shifter removed: 20 minutes
Exhaust/tunnel plate dropped: 30 minutes
cradle dropped: 1.5 hour (lots of little crap to remove before dropping it)
TT/trans/diff out as 1 unit all still together: 10 minutes
Putting it all back in was just as easy but took longer of course making sure everything was in place and torqued correctly but still done in 3 hours. I got lucky stabbing the input shaft into disc splines/pilot bearing on 3rd try.
Old Nov 2, 2009 | 08:19 PM
gppracer's Avatar
gppracer
I just pulled my diff out ,without dropping trans.I was surprised how easy it is.I did it on jack stands with two regular floor jacks.The diff was pretty light .The cradle is some what heavy. No real mechanic skills here.Just take your time.I was quoted $700 for install.No way it should take more than 4 hours labor by a mechanic.Do it, it's easy.
greg
Old Nov 3, 2009 | 12:01 PM
Mike Mercury's Avatar
Mike Mercury
http://mikemercury.home.att.net/342.htm
To considering a DIY diff change
