a shifting concern
Old Nov 2, 2009 | 01:50 PM
jimmymc's Avatar
jimmymc
Default a shifting concern
I have a 2000 vert 6 speed, and the car will only go into 6th gear at 56 mph , any other speed and it will not go . all other gears work fine . I even tried to put the the car in 6th with the engine off, with no luck.
any one ever have this trouble? the car does have 86,xxx on the clock and I don't no if it has had a new clutch, but it does not slip. also I changed to tyranny fluid when this was just starting to happen, and the fluid had a cloudy look, and could see shiny specks in it , I haven't been around in awhile, but I do trust that u won't hold that agance me.
Old Nov 2, 2009 | 08:12 PM
Hudson's Avatar
Hudson
wow
Old Nov 2, 2009 | 08:39 PM
jimmymc's Avatar
jimmymc
thank's for the reply , please any one help.
and thank you.
Old Nov 4, 2009 | 08:28 AM
jimmymc's Avatar
jimmymc
ttt
Old Nov 4, 2009 | 04:56 PM
jimmymc's Avatar
jimmymc
I guess their is not an easy fix for this? have a quote of 3500.00$
Old Nov 4, 2009 | 05:35 PM
lucky131969's Avatar
lucky131969
Are you saying, that at 55 or 57 mph, it will not go into 6th gear? ......on 56 mph?
Old Nov 4, 2009 | 06:15 PM
jimmymc's Avatar
jimmymc
just in that range, if I take it to 60 and pull the shifter hard and keep pumping the clutch ,it will go in by 55. sorry for not being precise
Old Nov 4, 2009 | 07:51 PM
dougbfresh's Avatar
dougbfresh
Why would you need to go into 6th below that speed anyway?
Old Nov 4, 2009 | 08:20 PM
jimmymc's Avatar
jimmymc
it will not go in at any higher speed
Old Nov 4, 2009 | 08:23 PM
Chuck A's Avatar
Chuck A
St. Jude Donor '08-'09
I havent had that problem with mine, good luck on finding the problem, and the soloution
Old Nov 4, 2009 | 09:00 PM
jimmymc's Avatar
jimmymc
thanks for reading
Old Nov 4, 2009 | 09:54 PM
Meech's Avatar
Meech
Never experienced that but I have an issue with 2nd gear popping out and grinding from time to time. Syncro, fluid change...or who knows what! Best of luck with your fix!
Old Nov 4, 2009 | 10:43 PM
jimmymc's Avatar
jimmymc
thanks , I don't want to do anything major if I don't have to, but for 3500.00$ I can rebuild tranny and new clutch,presurepalt, flywheel , and still have money for Christmas. but the car will be down for awhile . am I rite about that? 9 hrs labor to r&r the tyranny.
Old Nov 5, 2009 | 08:45 AM
Chuck A's Avatar
Chuck A
Most of the time its labor that kills everything the part can cost 25$ but the labor can be triple of that.
Old Nov 5, 2009 | 08:49 AM
TJ@RPMtransmissions's Avatar
0TJ@RPMtransmissions
Former Vendor
$3500 is aweful steep... one of our level 4 transmissions is $1895.00 exchange and we charge $350 to R&R the transmission, this will get you an upgraded transmission and no worries for many miles to come, we will also inspect everything in the driveline to make sure that you don't have any other issues.
$2245< $3500 for sure...
Old Nov 5, 2009 | 10:03 AM
Indy's Avatar
Indy
What happens when you have it in 6th and reduce the speed below 56 mph? I have never heard of this issue, but maybe something similar as with the reverse lockout?
Old Nov 5, 2009 | 11:20 AM
jimmymc's Avatar
jimmymc
It just loads up , it is only extremely hard to get it in gear, but once it is in gear I can cruse at highway speed no trouble at all
To a shifting concern
Old Nov 5, 2009 | 11:26 AM
jimmymc's Avatar
jimmymc
I think the person befor me put full synthetic fluid in the trans. and it destroy the paper ring on sixth gear
Old Nov 5, 2009 | 01:27 PM
Dope's Avatar
Dope
Resident moron
The speed thing boggles me. If you can't get it into 6th then I would think synchro problem BUT you said you can't even get it into 6th with the car off? Gotta be something broken or bent in there. Shift fork maybe?
Regardless, as mentioned, your best bet is to get a rebuilt tranny. RPM is #1 in my mind. Either R&R it yourself or pay them/someone else to do it. It's not too too much work to R&R a tranny. You could just use my clutch install guide and stop before you disconnect the torque tube from the bellhousing, and just pull the rear diff and tranny at that point.
$350 is a pretty good deal if you're local to them too.
Dope
Old Nov 5, 2009 | 02:20 PM
jimmymc's Avatar
jimmymc
thanks for the advice Dope< I had it happen on a trip the first time, was cruising at 70mph, and put it back to 5th to pass some trucks. when i went back to 6th it grind-ed just a bit and went to neutral, tried again and went rite in. did the same for the rest of the trip.
when i got home i change the fluid, but still got worse ,
is their any mixtures of fluid that help sinks work better?
