resetting oil life
Old Feb 26, 2002 | 04:44 PM
cat_gzz's Avatar
cat_gzz
Default resetting oil life
Hello all,
This is my first time posting on this forum. I just recently became a vette owner. Now I understand.
I changed the oil in my car over the weekend and I am having a hard time resetting the oil life indicator. I have followed the manual which says to hold the reset button for two seconds (I have held it up to 20 sec). The old oil life will clear and three underscores appear but that is all. Is there something else I can do to reset the oil life?
Thanks,
cat..
Old Feb 26, 2002 | 04:48 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: resetting oil life (cat_gzz)
what did it say when you shut it off and then turned it back on??
Old Feb 26, 2002 | 05:01 PM
cat_gzz's Avatar
cat_gzz
Default Re: resetting oil life (pewter99)
I put in the car in the garage and went to read the manual. I came back and started the car. It idled at about 1200rpm.
Message came on, reduce engine speed. I went ahead and shut it off. The next morning, I pulled out to run an errand and the engine light came on. The next time I started the car (30 minutes later), the engine light was off.
It hasn't came on since.
cat..
Old Feb 26, 2002 | 05:02 PM
SeaFive's Avatar
SeaFive
Make sure the key is turned to the ON position, but do not START the engine.
Then try it again. :cheers:
Old Feb 26, 2002 | 05:05 PM
cat_gzz's Avatar
cat_gzz
Default Re: resetting oil life (SeaFive)
Thanks,
I will try this tonight.
Will keep you posted.
cat..
Old Feb 26, 2002 | 05:07 PM
DAVS Y2K's Avatar
DAVS Y2K
Banned Scam/Spammer
Mine did not want to reset when using the proper procedure either but I was doing this with the driver side door open. When I closed the door and went through the sequence it worked! :crazy: :crazy: What difference having the door open as opposed to closed while doing this I don't know, but it worked when the door was closed.
Old Feb 26, 2002 | 05:11 PM
pogo's Avatar
pogo
I got lazy and let mine go so now it says CHANGE OIL NOW
I can't get that to go away.... Went through the procedure three times and it still says it.
Old Feb 26, 2002 | 05:17 PM
THRAP 42's Avatar
THRAP 42
Default Re: resetting oil life (pogo)
Cat_gzz,
Turn key to on, push throttle to the floor 3 times = oil reset. Easier than the other way.
later,
To resetting oil life
