2003 A4 Shift Linkage
Old Nov 4, 2009 | 03:28 PM
GoBallsDeep!'s Avatar
GoBallsDeep!
Default 2003 A4 Shift Linkage
Anyone have a part # and a place to find one or any tips on swapping it out? I put the car in park, went to put in drive and had no tension in the shifter. Pulled out the shifter to verify its attached at that end. I guess I snapped it at the tranny. I did a search and didnt come up w/ much. Any help is appreciated.
Old Nov 4, 2009 | 05:17 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
There is a small white plastic clip/retainer that fits inside the end of the linkage on the tranny side cable-These often break and the shift positions will be off and you may have no tension either---Most tranny shops carry them--It's a common part ---In my case when i had my trans built to a stage II --I forgot about the clip and lost it somehow and install my trans----It wouldn't shift--park was reverse and so on---
I went to the shop that rebulit it and they put one in for me-in 10 minutes---Check yours-----
Old Nov 4, 2009 | 06:02 PM
byronhunter's Avatar
byronhunter
Like this!
Old Nov 5, 2009 | 08:39 AM
GoBallsDeep!
can anyone help with a part #. I looked on GM parts and couldnt find anything. If I had a # I could. Thanks!
Old Nov 5, 2009 | 11:13 AM
timemender's Avatar
timemender
Your best bet when researching new replacement parts is forum vendor/sponsor Gene Culley who operates GMPartsHouse.com
Contact info is listed on his web site. Very competitive prices.
Call and talk to Gene.
Old Nov 6, 2009 | 09:15 PM
GoBallsDeep!
tblu92, i raised the rear and found that piece wasn't attached. The hole was a lot bigger than it would seem...no way that would snap on. I guess some part of it broke/fell off (I didnt see any cracks anywhere). I pulled it off an plan on taking it to a tranny shop. Aamco should have this? Its common? How much? No dropping exhaust or nothing! Stealership was quoting 5 bills. Im pumped if this piece is readily availible. Let me know...Im heading out in the morning. Thanks again all!
Old Nov 7, 2009 | 09:40 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I've got the parts, if you tell me which one is broken.
Old Nov 8, 2009 | 12:21 PM
GoBallsDeep!
^Thanks...I got a bushing from Aamco for free and fixed it. Just brought the guy a 6 pack of Heineken.
To 2003 A4 Shift Linkage
