Window motor inoperative
Old Nov 5, 2009 | 08:35 PM
buddan's Avatar
buddan
3rd Gear
Default Window motor inoperative
The right window won't work from either switch on my 99 , I just hear a click when I press the switch. There's only 9000 miles on the car so I'm sure the motor's not shot. Can anyone help?
Thanks.
Old Nov 5, 2009 | 09:01 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I would just about bet that the motor is just stuck. My drivers side window has done it twice when I first got the car. I took the door panel off and removed the speakers. I then tried the down button which puts the window in the down mode. Take a small hammer and peck the back of the motor a few times and it will take off. I have done this twice with good luck.
However, both times the window did get stuck again. Both times the window was stuck in the up position. I finally decided to fix it or eff it up. I took my drill motor and drilled a couple holes in the end of the window motor. I then took some electric motor cleaner I had left over from RC Cars and flushed the motor out real good while running it up and down. Since this, I have not had any problems out of the motor again. This has been about a year now. Knock on wood.
Old Nov 5, 2009 | 11:10 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
That sounds like good advice. Past that if it still doesn't work, then you need a new relay in the door control module, assuming you checked the fuse first.
Old Nov 6, 2009 | 10:17 AM
buddan's Avatar
buddan
3rd Gear
Thanks, I'll try that.
To Window motor inoperative
