Passenger side headlight won't raise...
Old Nov 6, 2009 | 12:11 PM
Valdostavetteguy's Avatar
Valdostavetteguy
Default Passenger side headlight won't raise...
There's no sound at all coming from the headlight. The light comes on but stays down. I've already replaced both plastic gears with brass ones so i know that's not it (plus there's no crunching noise).
My headlights usually take to or three tries to pop up anyway, now only one pops up. What would cause this?
I'm going to buy some corrosion inhibitor and try Bill Curlee's ground connector fix/clean-up on both sides.
Could it be anything else?
Thanks in advance!
Juan
Old Nov 6, 2009 | 06:08 PM
bigleman's Avatar
bigleman
if you turn the motor ****, will they come on then?
i'm having the same problem with my metal gears, they are binding when they go down and the computer isnt giving them enough power to pop back up
