Trans/Diff Oil Change (Picts)
Old Nov 6, 2009 | 01:51 PM
PR1AWRet's Avatar
PR1AWRet
Default Trans/Diff Oil Change (Picts)
On my Z06 2004 with the manual transmission ( I know, they only come with manuals) there is a sensor on the side where you fill the oil. I was under the assumption it looked like the transmission drain plug. This sensor is probably on other years/models and if so, please post year/model of your Vette. This is not an all inclusive detail how to change the oil but info I did not see on other posts.
Tools needed.
3/8" Ratchet
3/8" X 3" extension
3/8" X 10MM Hex Head (Not TORX)
7/8" Combination Wrench
(I tried a deep well socket but not enough room)
Oil Pump
Old Nov 7, 2009 | 10:13 AM
AJay's Avatar
AJay
Thanks for this post.
Very informative
Old Nov 7, 2009 | 10:36 AM
boblav's Avatar
boblav
St. Jude Donor '10
Capacity is right at 4 qts Dexron III ATF for the trans, and just under 2 qts of 75W-90 GL-5 Gear Oil, after adding the 4 oz bottle of GM Limited Slip additive for the diff. Fill to the top of the filler hole, with the car level.
Old Nov 7, 2009 | 09:36 PM
TEXHAWK0's Avatar
TEXHAWK0
If you have a small air compressor, I found that using air to push the fluid into the transmission works better than a pump.
Drill a hole in one of the fluid bottle caps to fit the fill hose and cut it to go all the way to the bottom of the bottle.
Drill a second hole to fit a small air line from the air compressor. Connect it to a trigger nozzle on the compressor, and set the air pressure low (10 psi or less).
Slowly pressure the top of the bottle, which forces the fluid up the tube and into the transmission. Takes less than 30 seconds to empty the quart bottle.
Mine started running out at about 3-1/2 quarts.
Another post...
http://forums.corvetteforum.com/c6-c...difficult.html
Old Nov 8, 2009 | 09:28 AM
Patches's Avatar
Patches
The tranny sensor which doubles as the fill plug on the Z06, is the tranny temp sesor. The regular MM6 C5 has no tranny temp sesor but the A4 does.
Old Nov 8, 2009 | 10:00 AM
bumble-z's Avatar
bumble-z
Patches, you stay right on top of things, here on the forum. Thanks! You're a Huge Plus for many of us. Keep up the excellent work.
Old Nov 10, 2009 | 08:11 PM
gppracer's Avatar
gppracer
Is there a filter you need to change also?
Old Nov 10, 2009 | 08:20 PM
lucky131969's Avatar
lucky131969
Auto only.....manual has no pan....no filter
Old Nov 10, 2009 | 08:32 PM
gppracer's Avatar
gppracer
thanks ,i have auto
Old Nov 11, 2009 | 08:32 PM
Paul 75 L82's Avatar
Paul 75 L82
Thanks for this thread, great pics.
To Trans/Diff Oil Change (Picts)
