Eliminate 02 sensor???
Old Nov 7, 2009 | 05:02 PM
tlmolyneaux2004's Avatar
tlmolyneaux2004
Default Eliminate 02 sensor???
Anyone know the resistance for the 02 sensors on a 97? I plan on getting rid of the cats.
Old Nov 7, 2009 | 07:02 PM
Indy's Avatar
Indy
I've heard of using O2 sims or programming the rear sensors out, but never of using resistors...
I would be interested in this too should this work
Old Nov 7, 2009 | 07:52 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
First off,,,O2 Sensors are NOT resistors. They act as batteries. The output voltage of an O2 sensor is 001 mv DC - 1 VDC They use heat from the exhaust, a catalyst and Oxygen to produce a voltage that changes with the oxygen content in the exhaust. Unless you can find O2 Simulators, you will need to have the rear sensors tuned out by a tuner.
Why do you want to get rid of the cats?????
BC
To Eliminate 02 sensor???
