2000 battery drain
Old Nov 9, 2009 | 04:52 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Default 2000 battery drain
will the 12 disk CD player in the trunk with the door popped open drain the battery in less then a week.
Old Nov 9, 2009 | 07:38 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
It shouldnt. Connect a DC Amp Meter in series with the negative battery cable and see what your BCM Sleep current draw is. It should be 20 milliamps. If its high, pull the power wire off the changer and see if the current drops.
When you turn the key to off, the BOSE Amp and system should shutdown. The CD Changer has a HOT at ALL TIMES power wire. It is also monitered by the serial data line and the BCM should shut it down if its working correctly.
If the BOSE relay is stuck on, that may be your issue. The realy supplies power to the AMPLIFIERS and is mini relay#43 in the instrument fuse panel
BC
