MPG Loss! Please help
Old Feb 27, 2002 | 02:26 PM
vettehead1995's Avatar
vettehead1995
Default MPG Loss! Please help
Changed the optispark,plugs,coil,airfilter,wires,and oil 2 weeks ago. The car needed a serious tuneup, I was averaging 18 mpg over a 1 year period of time, since then I am getting about 15.5mpg its not a huge deal but I wanted to know what the possible causes would be.
Thanks :cheers:
Old Feb 27, 2002 | 03:19 PM
Vetts Forever's Avatar
Vetts Forever
Default Re: MPG Loss! Please help (vettehead1995)
Can you please list What mods you have?
Old Feb 27, 2002 | 04:42 PM
Ranger's Avatar
Ranger
In my area, MPG goes down in the winter time due to the additives the government mandates be added to gasoline to reduce pollution in (relative) colder weather. You might check your log to compare your MPG at THIS TIME LAST YEAR. I lose 2-3 mpg this time of year. Just a thought.
Ranger
Old Feb 27, 2002 | 10:16 PM
2yellow's Avatar
2yellow
I would bet on some sensor going bad. You could read the codes and find out.
Old Feb 28, 2002 | 01:23 AM
Duck916's Avatar
Duck916
This may be a stupid question, but did the mileage drop occur shortly after the plugs, coils, wires and filter change? If so, there's a high probability one of those is the culprit.
Old Feb 28, 2002 | 02:50 AM
MDT's Avatar
MDT
vettehead1995,
I'd make sure that all the ignition wires and coil connections are good. There is a chance that you cracked the porcelian on one of the spark plugs when you installed; easy to do. I'd expect something like this if the drop in mileage was immediately after the tune up.
If the mileage decreased over a period of time then you may want to consider the oxygen sensors and the ECT sensor.
Good luck.
Mark
Old Feb 28, 2002 | 12:22 PM
jefffxdwg's Avatar
jefffxdwg
Default Re: MPG Loss! Please help (MDT)
Are you running the same tire pressure?
To MPG Loss! Please help
