Need help on a header install...
Old Nov 15, 2009 | 08:27 PM
davis31b's Avatar
davis31b
Default Need help on a ARH 1-7/8" header install...
disregard, got it.. P I T A!! Thats all im gonna say!
Old Nov 16, 2009 | 10:47 PM
vette0009's Avatar
vette0009
Default Need help on a header install..
Yeah, will pass on any info that will help the rest of us
I am going to be scabbin on a set of ARH Headers as soon as they are done being welded up and get back from the High Temp Coating place
So if you can provide the rest of us with any useful info we all would appreciate it
West Coast Bon
Old Nov 17, 2009 | 06:35 PM
davis31b's Avatar
davis31b
West Coast Bon
Basically I installed the 1-7/8" ARH headers.. I started with the passenger side, the drivers side I haven't started on yet. Some say the headers go in from the top on the passenger side, but I had better luck from the bottom.
I had to remove the spark plugs, wires, dip stick tub, coil pack assembly, valve cover, then underneath I removed the exhaust of course, took the wires off of the starter, removed the starter, removed the grounding strap on the block, and unclipped the oxygen sensor connectors from the frame. Then just make sure you have the car jacked up pretty high and slide them in from the bottom. Also make sure not to reinstall the oxygen sensor until you have the header bolted in, it will just get in your way.
I probably will do the driver's side here in a few days & will keep ya'll updated.
Old Nov 17, 2009 | 08:40 PM
Tony Mamo @ AFR's Avatar
0Tony Mamo @ AFR
Former Vendor
BOTH go up from the bottom....with very little fanfare I might add.
I found the AR fitment and install to be very nice all things considered.
You should remove a few of the basic things in your way however like the oil filter, ground strap, and spark plugs....on the passenger side the removal of the starter will make it very easy but you can actually sneak them in without removing it if your careful. Make sure you remove the positive cable from the battery though. Thats especially important when working on installing the passenger side header.
Hope this helps...
-Tony
Old Nov 17, 2009 | 10:35 PM
feeder82's Avatar
feeder82
alot easier than Kooks!
Old Nov 19, 2009 | 12:02 AM
vette0009's Avatar
vette0009
Default Help !!
Thanks, for the info thus far
A big thanks to Tony at AFR as well
My headers ought to be here by tuesday and then off to the Hightemp Coating place
I'm gathering up some info before tackle this thing
I find it takes away some of the Pain
you'all probably don't understand this, but some of the other Rookies around this place know what I'm talking about
Bon
Last edited by vette0009; Nov 19, 2009 at 12:08 AM. Reason: Misprint copyright (a)infringement
To Need help on a header install...
