Headlight problems
Old Nov 17, 2009 | 08:41 AM
Scott4569's Avatar
Scott4569
2nd Gear
Default Headlight problems
I just purchased a 2000 Vette with very low miles 27k I haven't found any real problems except one. The headlight are an aftermarket HID conversion that work great and have great visiability with one problem. When I turn the headlight off they dont go down however if I push the headlight lever forward after the headlight are off they go down no problem. Does anyone have any thoughts?
Scott
Old Nov 17, 2009 | 03:07 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I'm not familiar with the complications, if any, with the HID's on the C-5. But, it sounds like your headlamp switch needs to either be replaced or the contacts cleaned internally.
Old Nov 17, 2009 | 07:55 PM
jnaugle775's Avatar
jnaugle775
I had this in mine when I installed. I simply had tied the hot lead of the low beam to the relay. I left the ground on the low beam float. I put in a heavy ground strap for the light. I found that if I grounded the headlight connector ground everything works right. Hope this make sense
Old Nov 17, 2009 | 10:54 PM
Oldvetter's Avatar
Oldvetter
Common problem, your HID low beams do not pull enough current to "convince" the headlight module to close the headlights. There is a resistor you can add to the circuit to fix this.
To Headlight problems
