Rattle from front of engine!!!
Old Nov 19, 2009 | 07:46 AM
marinehacker202's Avatar
marinehacker202
Default Rattle from front of engine!!!
I fired up my '99 to go to work this morning and there was a small rattling sound from the front of the car. Higher RPM = more rattle. I popped the hood and tried to listen for a minute and it sounded (to me) like it was coming from the front of the engine, but I didn't have time to really inspect cause I had to go to work.
I'm gonna inspect further when I get off work this evening, and I was wondering if anyone had any advice on what to look for/common problems. I've got to figure this out pronto though because I am driving across several states next week for Thanksgiving. Thanks in advance!
Old Nov 19, 2009 | 08:42 AM
Itallian33's Avatar
Itallian33
Do you have a better discription of the sound....
THere are a lot of pulleys on the front of your engine that could be the culprit. Get a Mechanics stethiscope from your local parts store and use it to narrow down where the sound is coming from. If it is one of your pulleys, then that is an easy fix. Hopefully it isnt your Tensioner, GM is proud of those.. If it is the pulley on the tensioner, you can take it to a bearing supplier and they can match it and replace it for a ten spot (ask me how i know). Then you can take it to Napa and they will press the old one out and the new one in. The only other hard to find pulleys are those two idlers /tensioner ones for that 4 rib belt on your ac.
Old Nov 19, 2009 | 09:19 AM
ZEX-Z's Avatar
ZEX-Z
Sounds like the Harmonic Dampner. The rubber will let go of the pulley and it will walk, sound like a bad rattle. Change it out immediatly. or disaster.
Old Nov 19, 2009 | 09:36 AM
lucky131969's Avatar
lucky131969
Wow, that's a broad jump right to worse case scenario
As already mentioned, it could be as simple as a belt, tensioner, or pulley.
Old Nov 19, 2009 | 09:39 AM
marinehacker202
haha yeah i read that and was like, oh ****. Its funny cause I bought a new belt that I was gonna throw on this weekend anyway.
Old Nov 19, 2009 | 10:12 AM
Racin Jason's Avatar
Racin Jason
let's hope it's nothing serious. hopefully you have better luck then i do with sounds coming from the engine bay.
Old Nov 19, 2009 | 10:26 AM
hotwheels57's Avatar
hotwheels57
You might check your harmonic balancer (crankshaft) for evidence of wobble. It's common for them to fail.
Old Nov 19, 2009 | 12:24 PM
marinehacker202
just got back from lunch break, the noise got worse so I parked it and checked things further. It is indeed the harmonic balancer, wobbly as crap. the belt had walked halfway off. Is replacing this within Do-It-Yourself territory? tools aren't a problem, there is an Auto Hobby Shop here on base
Old Nov 19, 2009 | 12:37 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Yes, many here have done it. It takes time and having the right tools helps a lot. Do a search here on the forum and you will find all the info you need to complete the change.
Best of luck on your balancer swap!!
Old Nov 19, 2009 | 01:11 PM
lucky131969
Dammit....Zex-Z jinxed ya....
Old Nov 19, 2009 | 01:45 PM
marinehacker202
Haha. whatever. My only regret is not having a cam or anything to put in while I'm gonna have it that far apart
Old Nov 19, 2009 | 02:00 PM
marinehacker202
Ok, sorry to double post, but I have been trying to use the search function for like half an hour to find a how-to on replacing the HB. Does anyone know where to find this? Also, do yall think I should replace the tensioner too?
Old Nov 19, 2009 | 03:19 PM
hotwheels57
I don't know what keywords you used, but try this. I just found several pages of threads about the issue. I didn't read through all of them, but some contained hints, tools needed, etc.
In C5 Tech, use search this forum (in the red banner). Use keywords "harmonic balancer replacement".
After reading through those past threads, you might find someone close to you that could give you a hand. Or PM members who've DIY for additional assistance.
Old Nov 19, 2009 | 03:36 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I would not replace it unless it's not working correctly.
Basically, have to remove the rack through drivers side to get access to the balancer bolt.
You need some special tools to lock the flywheel, remove the balancer and to re-install the balancer.
Job is a PIA, but very do able with right tools. Also go with ARP harmonic balancer bolt.
Old Nov 19, 2009 | 04:45 PM
VetteDrmr's Avatar
VetteDrmr
Assuming that the problem is the damper bolt has backed out and allowed the damper to walk forward, there's a quick, but I would consider short term fix.
Take out the old damper bolt (they're torque-to-yield) and replace it with a new OEM bolt. This is by far the easiest way, because you don't have to go through the time and effort to make room to R&R the damper. Note that the torque on this bolt is KILLER. IIRC 45 ft-lbs. PLUS 270 degrees!
If you don't torque it down correctly (and this is a BIG pull!) the bolt will eventually work its way loose.
Now, the long term fix is to replace the damper. The main reason is that while the damper was working its way loose on the crank snout it erodes the metal, which causes a looser fit, which puts more load on the crank bolt, etc. BUT, that should take a while to happen.
HTH, and have a good one,
Mike
Old Nov 19, 2009 | 05:14 PM
bobby777's Avatar
bobby777
Western diamondback?
Old Nov 20, 2009 | 07:22 AM
marinehacker202
wait... what?
Hoping to start working on this tonight. Can anyone give me a parts list, I'm fairly confident I can get it done as long I actually own all the parts I'll need
To Rattle from front of engine!!!
Old Nov 20, 2009 | 09:46 AM
VetteDrmr's Avatar
VetteDrmr
Parts list is small: one damper bolt, one damper (if your're going to replace it at this time).
I just checked, and ajg1915 is right: you DO have to get the steering rack out of the way to get to the bolt.
Good luck, and let us know how it goes!
Mike
Old Nov 20, 2009 | 11:33 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Mike
Not hard to do. Turn your steering wheel straight and lock it in place so that it won't turn with a couple of bungy cords.
reason; airbag clock spring and steering position sensor.
Jack up the front of the car, remove both front wheels.
Disconnect tie rod ends from knuckles (Spindles).
Remove 13mm bolt from steering rod going to rack (drivers side).
Need 18mm flare wrench to remove power steering line.
Remove two 18MM bolts holding rack in place and then slide out. Make sure to disconnect electrical connector.
You'll need a drip tray or bucket to catch the PS fluid. Use a Turkey Baster to suck the fluid out of the PS resevoir.
Oh and watch out for your knuckle, gloves help.
Old Nov 20, 2009 | 12:06 PM
marinehacker202
Thanks! I'm gonna get parts tonight and probably start first hting tomorrow morning. Looks like I'll be in the shop all weekend, gonna be helping my friend rebuild his Mustang's trans too
