I noticed last night that there was no center console light whereby you can tell what position your transmission is in. Is this due to a faulty bulb or perhaps a fuse problem? Have a C5 Automatic
Can you give me some idea about how to fix this problem.
Trans Floor Shift Control Indicator Lamp Replacement
Remove the console to give access to the shift boot using these instructions from the Vette Essentials Website:
• Remove the floor shift control (the ****!).
• Remove the floor shift control boot assembly.
• Remove the lamp socket.
• Remove the bulb from the lamp socket
• Install the bulb to the socket.
• Install the socket to the shift boot assembly.
Replace the console
