Help! Having Issues with Switchback Leds
Old Nov 20, 2009 | 08:58 PM
danrowz's Avatar
danrowz
Default Help! Having Issues with Switchback Leds
I installed 60 count led switchbacks in new clear/black corners on a 02 z06. When I first started the car the running lights did not come on, when I turned the parking lights on the passenger side was white and the drivers side was amber, and when I turned the blinkers on the passenger side worked fine but the drivers side did not blink and stayed amber. This is driving me nuts, I'm almost ready to throw the stock ones back in. I have hid headlights with the in line resistor, and I also have the led flasher fix, which I tried bypassing just to make sure that wasnt the problem. Has anybody ran into similar problems like this? Do I need another resistor for the drivers side, cause the passenger side seems good.
Old Nov 21, 2009 | 02:21 AM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
Did you get these from Autolumination?
Old Nov 21, 2009 | 02:47 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Maybe the Driver's side is installed backwards, try rotating it 180 degrees...
Old Nov 21, 2009 | 06:38 PM
danrowz's Avatar
danrowz
The first pair of switchbacks that I got where from autolumination and they where all screwed up, they burned out, so I went with jw motoring
Old Nov 21, 2009 | 06:40 PM
danrowz's Avatar
danrowz
I tried rotating the switchback and it did not work at all, to my understanding they are only suppost to work one way, but I can be wrong
Old Nov 21, 2009 | 07:17 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Did you follow the troubleshooting steps I emailed to you? I haven't heard back from you.
Old Nov 22, 2009 | 12:01 PM
c5vetteguy's Avatar
c5vetteguy
OK, I can't help then. I also bought the AL 60s and they blew fuses. Returned them for 48s and are working fine. Supposedly all AL's 60s had a problem in C5s, at least when they were first introduced.
Good luck with your troubleshooting. They do look when working properly.
Old Nov 22, 2009 | 12:10 PM
JW Motorsports
Banned Scam/Spammer
They use a different version than we do. Ours are actually pretty reliable.
I sent a few thing to check to the OP. I'm thinking he missed a fuse the other brand switchbacks popped.
Old Nov 22, 2009 | 08:30 PM
danrowz's Avatar
danrowz
weird thing, I turned on the car and the running lights came on, but the drivers side is white and passenger was amber, when I turned the lights on it switched, the driver side was amber and passenger side was white and the switchback on the driver side was not working with the blinker? I think im going to try another switchback or Im gong swaping the driver side for the passenger side to see what happens before I order another one.
Old Nov 22, 2009 | 08:58 PM
JW Motorsports
Banned Scam/Spammer
You don't need to order a new one I will replace them under warranty if they're defective.
Old Nov 23, 2009 | 03:03 AM
tstar's Avatar
tstar
I have an idea, on the one that's working bass ackwards. If you look at the wires coming out the back of the bulb, two are bent perpindicular to each other, those are the Grounds. The other two are offset and feed the White and Orange LEDs, I bet they are reversed by the sounds of it... See if you can bend each one to the opposite side of the connector from where they are now...
Tim
Old Nov 23, 2009 | 08:47 AM
cdkcorvette7's Avatar
cdkcorvette7
Let JW help you, he stands behind his products.
Old Nov 23, 2009 | 04:43 PM
danrowz's Avatar
danrowz
thanks alot guys for all the feedback. I will try swaping out the one switchback, I just have to take it off the car and I will ship to jw.
Old Nov 23, 2009 | 04:44 PM
JW Motorsports
Banned Scam/Spammer
I was just writing you an email. Try what he said in post 11 also. That sounds possible.
To Help! Having Issues with Switchback Leds
