Locating the Tach wire...
Old Feb 28, 2002 | 10:31 AM
Phil97SVT's Avatar
Phil97SVT
Default Locating the Tach wire...
What is the easiest way to get to and locate the tach wire on the PCM? I have checked the archives and seen a few pics but nothing that helps. TIA
Old Feb 28, 2002 | 10:37 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Locating the Tach wire... (Phil97SVT)
Its the #10 wire.. I think its white..
Old Feb 28, 2002 | 10:48 AM
Phil97SVT's Avatar
Phil97SVT
Default Re: Locating the Tach wire... (ICULUKN-C5)
I dont have a shop manual for the corvette yet. :confused: Where is the PCM located and are the pin's numbered?
Old Feb 28, 2002 | 04:17 PM
Kent1999's Avatar
Kent1999
Confirmed -- it is the #10 wire (white in color) on the RED PCM connector.
Hold the connector so that the connector tabs are on top, and the wires are pointing out the back of the connector away from you. #10 should be a white wire on the bottom row, 10th wire in from the left edge.
The PCM is located behind the RF fender, between the wheelhouse and the dash panel, below the battery.
Cheers,
Kent
[Modified by Kent1999, 1:26 PM 2/28/2002]
Old Feb 28, 2002 | 06:17 PM
jetskifast's Avatar
jetskifast
Default Re: Locating the Tach wire... (Kent1999)
White wire #10 pin is under grey cover held in place by one screw.
Ignore writing on this picture, but you can see grey covers.
[Modified by jetskifast, 2:17 PM 2/28/2002]
Old Mar 1, 2002 | 03:35 PM
Phil97SVT's Avatar
Phil97SVT
Ok I got the access panel off and located the PCM. Which cover do you remove? There are 2 big gray covers, 1 medium harness with no cover /red clip, one small harness with no cover. Do I remove the cover closest to the motor or outside of the car and is there only one red harness? I am having problems locating the correct wire for the hookup. Can anyone help me~!!!!
To Locating the Tach wire...
