c5 z06 engine swap
Old Nov 25, 2009 | 02:24 AM
petrov83's Avatar
petrov83
Default c5 z06 engine swap
I have a 2003 c5 z06 and I want to make it into a hardcore street/race car. Comfort and noise are not an issue. Main purpose is durability, top speed and acceleration. I was first thinking of going twin turbo but I want alot of horsepower without blowing up. I guess I would be happy with 600whp+. But then I started looking at engine swaps and i was thinking of going with a chevy crate engine or maybe one of the new LS7 engines. Any suggestions would be of help. Also what is the biggest most powerful chevy engine that can fit into the c5 engine bay? I will prob drive the car 2-300miles per month so its just for fun.
Old Nov 25, 2009 | 05:42 AM
Its_Go_Time's Avatar
Its_Go_Time
How much money do you have?
Old Nov 25, 2009 | 09:38 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
^^Your best bet is to go the forced induction route. You can easily achieve 600rwhp, maintain the drivability of the car, and do it less expensively than if you go NA.
However, with that power level you will need to improve your drive line to handle the increased power and also some wider rims and tires. Might want to mini-tub the rear.
Old Nov 25, 2009 | 12:01 PM
lucky131969's Avatar
lucky131969
Exaclty...what is your budget?
Old Nov 25, 2009 | 02:41 PM
Gooser's Avatar
Gooser
Spray it!!!
Old Nov 26, 2009 | 03:35 PM
petrov83's Avatar
petrov83
my budget is around 20k
Old Nov 26, 2009 | 03:36 PM
petrov83's Avatar
petrov83
i have been looking at the STS turbo kits.
Old Nov 26, 2009 | 06:57 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
I've had a 600+rwhp car and it was a handful.
What good is high hp when you can't hook the tires anywhere in the first 3 gears? Downshift at 100mph into 4th and punch the gas, the turbos hit and you loose traction.
If I was about to dump cash into a setup, I'd keep it simple using some 317 casting heads to lower compression and bolt up an A&A superchager kit with an 8 rib pulley system. 10 psi with a good clutch.... and enjoy.
Put some money into the brakes, tires, and a safety harness.
Old Nov 27, 2009 | 02:05 PM
petrov83's Avatar
petrov83
yea i am going to put muich wider tires and reinforce everything
To c5 z06 engine swap
