ls2 injectors
Old Nov 25, 2009 | 09:56 PM
vet777's Avatar
vet777
Default ls2 injectors
I purchased ls2 intake / 90mm tb for my 01 c5 not installed yet, i would like to add ls2 injectors, will they work with the ls1 fuel rails & harness? are they worth the effort ?
thanks.
Old Nov 25, 2009 | 11:14 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Installing an LS2 intake is a step back-wards! The LS6 Intake actually flows better than the LS2. If you want a better 90mm manifold & 90mm TB use a FAST. Theres an extensive post on this very topic.
What are your MODs??? I believe the LS2 injectors have a different connector. Just get some SVO 30's. You know that you have to tune the new injectors into your car. It wont work properly if you don't.
Unless you have headers, ported heads and a decent cam, increasing intakes, injectors etc is a waste of cash. You wont gain much for the major cash out lay.
BC
