Are 1999-2005 pcm interchangeable
Old Nov 26, 2009 | 03:20 PM
shoeboxvette's Avatar
shoeboxvette
Default Are 1999-2005 pcm interchangeable
I've got an 1999 ls1 engine Tow company fubared the pcm. As with any computer equipment as soon as the next one comes out the old is slow and obsolete therefor Can I use a newer model pcm.
With slight mods as ls6 intake,heads,cam the motor is basically a ls6.
What pcm should I start with, I'll have to have it reflashed and have items deleted or turned off
Thanks for help.
Randy
Old Nov 26, 2009 | 06:52 PM
TurboBerserker's Avatar
TurboBerserker
The short answer is nope.
The longer answer is that you can switch PCM "years" by rewiring the connector plugs. here's a how-to on switching a 97-98 to 99-02 PCM but the principle is the same for all swaps. You will get an idea if this is something you want to try...
Honestly, however, there is nothing to be gained if you already have a 99. Just replace it with the correct replacement PCM from the auction site.
Old Nov 26, 2009 | 07:35 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
100% on the mark!
BC
Old Nov 26, 2009 | 08:22 PM
shoeboxvette
looking at the pcm pin locations the 99-05 are the same. As this is an engine swap I'm not going to need all the bells and whistles.
Old Nov 27, 2009 | 12:42 PM
lucky131969's Avatar
lucky131969
Not sure what schematics you are looking at, but 99-05 are not the same pinouts............
Old Nov 27, 2009 | 01:28 PM
TurboBerserker
Yep, the pinouts are definitely *not* the same for 99-05, and certainly not for 99-02 to 03-04. 2004 is the last year of the C5 model. C6 pinouts are definitely not the same.
Basically, each year and each model gm car has a different pinout.
Old Nov 27, 2009 | 02:23 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
C6 (05-present) Its a CAN buss controlled network. The PCM Plugs are completely different than a C5 PCM plug.
Old Nov 28, 2009 | 03:22 AM
shoeboxvette
I printed out the pcm connector end views for 99-02 dam all those years of school I think I can read Pin location, wire color, circuit No., and function are all IDENTICAL. 87-88 are different, 03+ are also diff.
But 99-02 are the same.
Old Nov 28, 2009 | 03:28 AM
shoeboxvette
Originally Posted by TurboBerserker
Yep, the pinouts are definitely *not* the same for 99-02, and certainly not for 99-02 to 03-04. 2004 is the last year of the C5 model. C6 pinouts are definitely not the same.
Sorry to pee in your cheerios but the pinouts for the 99-02 vette are Identical
Printed out the PCM connector end view from
http://corvetteforum.shelor.net/Corv...ts/Default.asp
Old Nov 28, 2009 | 05:09 AM
65GGvert's Avatar
65GGvert
Your first question was 99-05 then you went to 99-02, then talked about 87-88. I think part of the problem here is fingers on the keyboard. Is your question "are the 99-02 pcm's interchangeable?" No way are the 99 and 05 the same.
Old Nov 28, 2009 | 11:03 AM
lucky131969
True, but your original statement was "looking at the pcm pin locations the 99-05 are the same."
I guess you are peeing in your own cheerios..........
Old Nov 28, 2009 | 01:30 PM
shoeboxvette
Hey Haole's Mahalo for all the useful information instead of what can be done.
Mahalo!
Old Nov 28, 2009 | 01:39 PM
TurboBerserker
I fixed my typo. Not peeing in my cheerios at all
As my first post said, just replace with the 99-02 replacement (which is an 02 PCM).
Old Nov 28, 2009 | 01:43 PM
shoeboxvette
Hey Haole's Mahalo for all the useful information instead of what can be done.:
Mahalo!
Old Nov 28, 2009 | 01:50 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
lucky, what was that you said about wasted key strokes?
Old Nov 28, 2009 | 01:55 PM
65GGvert's Avatar
65GGvert
Mahalo!
Your original question, that I answered was, are the 99-05 pcm's interchangeable. I told you no. What other useful information did you expect. Ask the question you want answered and you may get the answer you expect. Your question was answered by several people trying to help you and you got snotty. Sounds like you've already made up your mind, so why ask.
Old Nov 28, 2009 | 06:14 PM
lucky131969
Yep.......
To Are 1999-2005 pcm interchangeable
Old Nov 28, 2009 | 06:57 PM
shoeboxvette
Thanks for help.
Randy
ALL I ASKED IS if you jack@@ses can read!!!!!
I Have a 1999 ls1......Can I use a newer model PCM.
Mahalo!
Have a nice Day
Old Nov 28, 2009 | 07:07 PM
65GGvert's Avatar
65GGvert
Mahalo!
Have a nice Day
Apparently, not only are you a jerk, you can't read. Go back and read your first post. "Are 99 and 05 PCM interchangeable"
Find your help somewhere else, I'm done.
Old Nov 28, 2009 | 11:16 PM
TurboBerserker
Mahalo!
Have a nice Day
I answered you. Then your posted some nonsense. Many of us corrected your flawed statements. You repeated the flawed statements and coped an attitude. People tried to point out that you maybe "fat fingering" your posts leading to confusing. You acted like a jerk and continue to do so.
Tell you what, chum. Go buy your 2005 PCM that is "faster" and "better" and install it. Then report back.
