heater problems
Old Nov 29, 2009 | 01:13 PM
1motime's Avatar
1motime
Default heater problems
hey guys i have a 1998 corvette, the heater does not work on the floor or upper settings, when i put in on defrost the heat only works on the passsenger side. what could the problem be. Thanks in advance
Old Nov 29, 2009 | 01:59 PM
1motime's Avatar
1motime
a little help will do
Old Nov 29, 2009 | 05:40 PM
corvette430hp's Avatar
corvette430hp
I think the vacume lines are probably rotted thru. I hade the same problem. it was due to a defect with original batteries. They would leak down acid onto the vacume lines for the heater doors/ducts. then the doors would not open or close. I had to pull the battery and the battery holder that it sits on. the vacume lines all had been eaten away. Spliced some new lines in and its been fine. let me know if you need more info
Old Nov 29, 2009 | 11:36 PM
1motime's Avatar
1motime
thanks for the info
Old Nov 29, 2009 | 11:54 PM
1motime's Avatar
1motime
member (carcass) has a post under climate control, I did that, now my heat works normal, thanks for the info anyway.
Old Jan 2, 2010 | 11:10 AM
Paladin62's Avatar
Paladin62
Did you have any success resolving your heater problem? I have the same problem with my 99.
Old Feb 16, 2010 | 05:08 PM
1motime's Avatar
1motime
yes
To heater problems
