160 Degree Tstat with stock computer programming will it set off the CEL?
Old Dec 2, 2009 | 04:36 AM
98BuickRegalGS's Avatar
98BuickRegalGS
Default 160 Degree Tstat with stock computer programming will it set off the CEL?
I know some cars will set off the check engine light if you get too cold of a Tstat without programming. Is this the case with the C5? Is 178 a better choice? Stock appears to be 195 so 160 is a lot colder. Im use to going from 195 down to 180 degree tstats in my past cars.
Old Dec 2, 2009 | 05:24 AM
vettenuts's Avatar
vettenuts
The stock thermostat can be modified to open at lower temps by using a small shim. Cost is about $1. I prefer the 180 but it is colder up where I am than your location.
Old Dec 2, 2009 | 07:54 AM
92mr2turbo's Avatar
92mr2turbo
My car came with a 160*F and it runs on the highway at 175-185 cruising. No CEL's. No reprogramming of nothing. I have a 2000.
Old Dec 2, 2009 | 08:18 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Originally Posted by 98BuickRegalGS
I know some cars will set off the check engine light if you get too cold of a Tstat without programming. Is this the case with the C5? Stock appears to be 195
A 160 degree thermostat will not set a trouble code and turn on the MIL on the C5. I've found that a stock 187 degree thermostat, that's been modified following vettenuts writeup, will maintain coolant temperatures in the 180-185 degree range at cruising speeds.
Old Dec 2, 2009 | 03:18 PM
lomoman's Avatar
lomoman
Default 160 Tstat
I have a Summit 160 stat installed...no problems (knock on wood)
To 160 Degree Tstat with stock computer programming will it set off the CEL?
By Michael S. Palmer | 2026-06-03 09:39:05
