MGW doesnt have stops?
this is a deal breaker for me. im probably going to send it back.
The Hurst DOES have adjustable stops. I've got'em and I'm keep'in'em!
i have more experience than usual with shifters.
the quality of this shifter is impressive. the machine work and finish is great. it just doesnt have stops. i want stops. i dont care if i dont need stops per someone's advice/opinion. i want them.
some people seem to take it that i am somehow bashing MGW.. absolutely not. its a darn fine looking mechanical specimen and the one i used in the past felt great. truly impressive.
i just didnt realize that one of the key features i wanted wasnt there. my own fault.
And for future reference, when you ask for help or opinions on this forum it's not usually a good idea to attack those who give it.
my idea of a shifter stop, is when the shift is fully engaged and flexed a little to over engage.. you bring a stop up to that point and go just a hair beyond it (almost like setting preload on a lifter if you will), to avoid over-doing it.
speaking of attacking. thanks for the condescending explanation. i almost feel like i can graduate kindergarten now.
thanks for the input
LONESTAR: interesting input. makes sense.
I posted the info below in your other post. You can adjust stops to work properly with the C5 tranny. Some people like stops some dont. I perfer them. Kirban quik shifter has them. They work excellent.
If you set up the stops properly, you can make a complete shift and not hurt the trans.
Heres what I posted in your other post:
The shift rail assy inside the transmission will only allow the sliding/ rotating arm inside the trans to travel a specified distance. The distance is slightly more than the complete throw that is required to engage the coupler on the gear to fully couple the gear/s. The coupler that connects the two gear assemblies together is the limiting factor. Once it slides home, any further motion is caused by the additional motion the shift rail has before it bottoms out.
If you really examine the shift throw, you will see that once the shift handle makes the gear shift, you can FORCE the shifter handle a good bit further than is require to complete the shift.
To me, "IMHO" that is a big waste of motion, hard on the internals and just plain sloppy.
I was fortunate and purchased a KIRBAN Shifter which has STOPS. Many people who purchase aftermarket shifters avoid shifters with stops or take the stop screws out for three reasons.
I’m sure there are other reasons but, here are the three reasons that I have surmised over the past 11+ years of C5 ownership and repairs and talking to people who install aftermarket shifters:
- The trans has internal stops. I don’t need additional stops. Just something else to worry about.
- They come out of adjustment and screw up the tranny.
- I didn’t know what they were for or how to adjust them so I ordered a shifter without of them.
I use the shift stops to my advantage. I shift into the 1-3-5 forward position and adjust the front stop. Then shift into the 2-4-6 gates and adjust the rear stop. When the shift handle has the gear fully engaged, let go of the shift handle, screw the stop screw in for those gates until it "JUST" touches the shift handle in the shifter housing and then back it off a thousands or so.
When you shift, the handle will now fully engage the gear and STOP against the shifter stop. No more excess motion. No more sloppiness, and no internal wear from excessive force of going past the fully engaged position. You can take the car for a ride and see how it feels. Some times, you will need to move it in or out a thread or two to adjust the shift feel.
Its very important to apply RED lock tight on the adjusting bolt and then LOCK it down with the lock nut so they don’t come out of adjustment .
Now you will get a SNICK, SNICK sound when you hit the stops and a POSITIVE feeling when you hammer the gear. People who have driven my car often say, “WOW, that shifter really feels nice!”
My 2 cents on shifters and stops
Bill
the smoothest tranny ive ever shifted was a Gforce T-5 with a MGW that belongs to a good friend of mine who bought my old notch back foxbody..
anyhow, i got all the info i needed.
Bill: i thanked you sincerely on the other thread that was intended to be more tranny specific. I really appreciate you sharing that info.
