Too Many Codes
Old Mar 1, 2002 | 08:40 AM
DI2FLY's Avatar
DI2FLY
Default Too Many Codes
Please help. My car is really screwin' with me.
First I get a code 32, so I change the EGR switch and the code goes away.
Right away I get another code. This time its 36. So I change both MAF relays, and that code goes away. Now, right away I have a code 33 set.
What's going on ? Thank you in advance. :smash: :confused: :cry
Old Mar 1, 2002 | 09:54 AM
David-F's Avatar
David-F
Default Re: Too Many Codes (DI2FLY)
Check to see which relays you used the 86 has two different relays if they get put in backwards you will get a code 33, so you might want to check it out. If you have two of the same relays in there you need to stop by a GM dealer and get the correct relays and install them were they need to be. One of the ways to know if they are hooked up correctly is to see if a code 33 sets if it does swap them.
David Fulcher
Old Mar 1, 2002 | 09:53 PM
DI2FLY's Avatar
DI2FLY
As soon as I posted this, I realized I was in the wrong section.....Sorry :rolleyes:
To Too Many Codes
