Replace Valvecover Gaskets????
Old Mar 1, 2002 | 06:52 PM
Closer_2001's Avatar
Closer_2001
Default Replace Valvecover Gaskets????
I'm going to swap out the valvesprings this weekend. Is it necessary to replace the valve cover gaskets when pulling covers. They have less than 1k miles on them.
Old Mar 1, 2002 | 07:41 PM
davidfarmer's Avatar
davidfarmer
Default Re: Replace Valvecover Gaskets???? (Closer_2001)
no. The only gaskets on the entire engine that need replacing are the head gaskets.
Dave
Old Mar 1, 2002 | 11:04 PM
SteveL's Avatar
SteveL
No need to replace the valve cover gaskets, just clean the oil and dirt off of them before reinstalling.
I just changed my valve springs this past weekend. I had one rocker arm that lost one side of the bearings.
Just in case you don't have torque specs:
valve cover bolts are 106 in lbs(~9 ft lbs)
rocker arm studs are 22 ft lbs
Steve
To Replace Valvecover Gaskets????
