Exhaust replacement on Jack stands
Old Dec 4, 2009 | 01:22 PM
DEMOZG1000's Avatar
DEMOZG1000
Cruising
Default Exhaust replacement on Jack stands
Hey guys I need a little advise. My brother has a 2003 z06 and I have a 2003 AE. I assume his titanium exhaust will fit on my ae coupe. I am just looking for a little more aggressive sound. Can the swap be done on jack stands or do I need a lift? About how high do I need to get the car to remove the exhaust? Thanks
Old Dec 4, 2009 | 01:26 PM
87SAM's Avatar
87SAM
I did it but would not do it again. It is a very scary prospect as the rear bumper needs to be 30 some inches in the air. Take it to someone with a lift would be my advice.
Old Dec 4, 2009 | 01:29 PM
lucky131969's Avatar
lucky131969
Nope. At least 30 inches. Better off taking it to a muffler shop you can trust.
Old Dec 4, 2009 | 03:01 PM
Neato's Avatar
Neato
It takes 20-30 minutes to do on a lift
They can't charge too much.
Old Dec 4, 2009 | 07:15 PM
BanditDude's Avatar
BanditDude
It can be done. I would recommend a lift, if you can use one for reasonable cost.
Old Dec 4, 2009 | 07:53 PM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
I have done it about 3 times, and didnt have a problem , but like others say I think a shop will do it for a small charge,
Old Dec 4, 2009 | 09:55 PM
Vegas Vette's Avatar
Vegas Vette
Easy to do on stands done it to many times to count.
Old Dec 4, 2009 | 10:57 PM
rebelheart's Avatar
rebelheart
I have done it on jack stands twice with no problems.
Old Dec 5, 2009 | 12:51 AM
jrose7004's Avatar
jrose7004
I did it on a buddies lift! Much easier.
Old Dec 5, 2009 | 01:09 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Yep 31 inches worked for me.
Old Dec 5, 2009 | 03:07 AM
Neato's Avatar
Neato
how tall were your stands ?
how did you jack it that high ? with a floor jack ?
I used my own lift
Old Dec 5, 2009 | 09:54 AM
rws.1's Avatar
rws.1
like others have said it is a high lift... I had to add a lifting saddle to my jack ...a 4x4 sandwiched between 2 2x6's to get 8 inches of extra lift hieght...
drop the rear sway bar, remove the gas tank shields and you are good to go...
Old Dec 5, 2009 | 10:07 AM
Patches's Avatar
Patches
A forum member posted these a while back.
I've done it on jack stands but have since mended my ways. Much easier - and safer - on a lift.
Old Dec 5, 2009 | 11:35 AM
rboineau's Avatar
rboineau
The swap nets you very little exhaust sound improvement. I could barely tell any difference at idle once I swapped my '03 Coupe's catback to a Z06 titanium. Full throttle, windows down I could hear some difference but again not a lot to my mind. Unless you are wanting the weight loss and rust-free material it isn't worth it.
Old Dec 5, 2009 | 01:13 PM
Neato's Avatar
Neato
I did mine for performance , not more noise.
Weight loss and flow capability W/O the drone.
Old Apr 15, 2010 | 05:39 PM
gcolella's Avatar
gcolella
bump
Old Apr 15, 2010 | 06:53 PM
jmoody66's Avatar
jmoody66
If you want a little more sound quality to it have the Ti mod done.
Old Apr 15, 2010 | 07:01 PM
jrose7004's Avatar
jrose7004
A lift will make it much easier!
To Exhaust replacement on Jack stands
