OEM Fog Light ???
Old Dec 5, 2009 | 10:03 PM
will9455's Avatar
will9455
3rd Gear
Default OEM Fog Light ???
Does anyone know if the non-Z06 C5's come prewired for fog lights? I want to install the OEM fog lights and need to know if I need to buy a harness as well as the lights and switch. Thanks.
Old Dec 6, 2009 | 08:21 AM
chuffo302stang's Avatar
chuffo302stang
from what I understand you need the underhood harness but it is wired in the car
im not 100% sure
I looked into this then said the hell with it and took out the black housing in there and installed oem Z06 screens. The car now runs cooler
Old Dec 6, 2009 | 09:19 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you have a ZO6, you do NOT have the harness for the Driving Lights. All you need to do is get a duel switch for the trunk / driving Lights, pop it in and install a power wire from the under hood fuse center to the lights. The switch just plugs in to the harness inside the dash and the relay is already there inside the fuse box. Just ground the lights to the skid plate frame and your all done.
You will need to purchase a nut clip to mount the lights in the heade bar. NAPA has them.
Bill
Old Dec 7, 2009 | 10:07 AM
clif's Avatar
clif
St. Jude Donor '09-'10
I have a 99 C5 that came for OEM fog lights. It is an A4 vert.
Old Dec 7, 2009 | 10:13 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
I'm not sure what you are asking. My '01 vert is equipped with factory fog lights. Were they optional?
To OEM Fog Light ???
