Head bolt pattern and torque #s
Using the sequence illustrated above, torque all 10 15mm bolts to 22lb-ft.
OPTIONAL: Safety check! One one side of the motor install 2 pushrods (one exhaust, one intake), the rocker pedestal, and two rockers...then turn the motor over by hand two full turns. While this method wont be exact, if the engine didn't stop when you were turning it you most likely installed the cam correctly. If it felt like it stopped at one point and wouldn't go further, chances are a piston is hitting a valve and you need to disassemble things and go back to the dot to dot part, OR, your cam is huge and the piston to valve clearance is ZERO (it'd take a really big cam for this to happen)
Ok, now for a GREAT tip from Scott99Z. Take a felt tip marker and draw a horizontal line on the head of each bolt. This is very important.
Now, using the sequence illustrated above, turn all 10 15mm bolts an additional 90 degrees using a large socket wrench and a lot of muscle. Try to get as close to 90 degrees as possible...you may have to do multiple turns of 30 degrees or 2 turns of 45 degrees. When done all the lines on the bolt heads should be totally vertical.
Next, again using the sequence above, turn bolts 1 through 8 another 90 degrees. This will take an immense amount of effort...if you have a buddy helping both of you should turn the wrench simultaniously. These 8 bolts will now all have horizontal lines on them
Using the sequence above, turn bolts 9 and 10 an additional 50 degrees. Again, this will take a lot of effort. 50 degrees should result in a diagonal line on the bolts
Finally, using the sequence above, torque bolts 11 through 15 to 22 lb-ft.
