Rear Spindle Question
Old Dec 6, 2009 | 07:26 PM
2Phast4U's Avatar
2Phast4U
From: anywhere you go, there you are Bentonville, Arkansas
Default Rear Spindle Question
I just put new tires on my '04. When the tire shop took off my right rear wheel, the large nut that goes on the spindle just fell out of the hub. THe shop guy put it back on, using some lock tight and an impact wrench. My question is, is there a lock nut that is supposed to go behind the larger one? I saw no place for cotter pin or anything that would keep it from backing off again if it got loose.
Old Dec 6, 2009 | 08:15 PM
Bill Dearborn's Avatar
Bill Dearborn
There is no lock nut or cotter pin. I would be concerned with the way he fixed the problem though. The Service Manual says to "Tighten the drive axle spindle nut to 160 N·m (118 lb ft)". No way to know whether he overtightened the nut or didn't tighten it enough. The locktite may make it hard to do but I would remove the nut and re-install it using a torque wrench.
Bill
Old Dec 7, 2009 | 08:18 PM
2Phast4U's Avatar
2Phast4U
Bill
Thanks for the information Bill, I will have that checked.
Old Dec 7, 2009 | 08:53 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I thought those were one-time use nuts?
Old Dec 7, 2009 | 09:09 PM
2Phast4U's Avatar
2Phast4U
Sounds like I need to do a bit more research before I drive it much. Anyone else have any info?
Old Dec 7, 2009 | 09:43 PM
Its_Go_Time's Avatar
Its_Go_Time
Think they are. And when you go to the dealer to buy a new one, it takes a different socket...It went up from 33mm to 34mm. Had to buy a new socket as well as the nut.
Old Dec 7, 2009 | 09:45 PM
MNCrystalRed2011's Avatar
MNCrystalRed2011
As long as you keep them torqued correctly, you should not have to worry about replacing.
I check the torque each time I prep the car for an HPDE event. Every once in awhile one of them is a little loose.
To Rear Spindle Question
